      05-21-2010, 05:41 PM   #1
RBull
Drives: 2007 M Coupe
Z4M tire opinions
I'm looking to replace what I have when car was purchased- an unmatched set of eagle gt and OE contis in stock sizes. Would like to hear opinions on other brands of both OE size tires and
f 245 40 18
r 275 35 18
Right now I'm considering the summitomo, Hankook V12 and dunlop direzza.
Thanks
      05-21-2010, 06:01 PM   #2
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
In for this too
      05-21-2010, 06:05 PM   #3
mousitch
Dark Sider
mousitch's Avatar
129
Drives: 2008 Space Gray Z4MC
2008 Z4M Coupe  [7.50]
I'm loving the v12's in f 245 40 18 r 275 35 18. Sticky but maybe a hair less responsive than the Conti's. Look good too!
      05-21-2010, 06:35 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^Responsiveness seems to be the most common "wish was better" comment about V12s
Have you played with the pressures at all to see if responsiveness improves?
The 245/275 combo is at the limits of the OE wheels.
How do they look?
      05-21-2010, 06:41 PM   #5
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
One problem with the Direzza Star Specs is a limited OE size selection for the rears.
The only choice is to go up to the 275s, which are a little on the porky side at 32lbs.
      05-21-2010, 06:46 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
In OE sizes, another extreme perf, choice is ADVAN Neova AD08
Tested against Direzza & Bridgestone RE-11
http://www.tirerack.com/tires/tests/...y.jsp?ttid=118
      05-21-2010, 07:17 PM   #7
RBull
did you experience the oe tires and how does your set up compare- handling, ride, tramlining etc? any issues with uneven wear, ride etc. I see you're also dropped on the H&R's which is the set up I'm moving to.
      05-22-2010, 01:48 PM   #8
fitchesbass
Drives: BMW
They offer a 265/35/18 for the rear so you don't have to go to 275s....
911 Carrera project car
Previous:
E92 M3 ZHP - Sold
E86 Z4M - Sold
E36 M3 - Sold
      05-22-2010, 02:52 PM   #9
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Yes but the diameter of the 265 is quite a bit smaller than OE.
OE 255/40 is 26
the 265/35 is 25.3
http://ejelta.com/tiresize/index.htm...=18&maxdelta=2
      05-22-2010, 03:13 PM   #10
RBull
^+1.
That's not something I want to do.
      05-23-2010, 12:21 PM   #11
jragan
Imola Lover
jragan's Avatar
Everyone who runs the Direzzas LOVES them. I use them for track tires as well and they're fantastic.
Hers: 997-1 C4S: Pics
      05-23-2010, 03:51 PM   #12
RBull
^thanks. what size are you running and are there are down sides?
      05-23-2010, 04:50 PM   #13
jragan
Imola Lover
jragan's Avatar
http://images53.fotki.com/v440/filen...tockWheels.png green columns.
Down sides? More rubber on front has the slightest negative effect on turn-in-ability (but it never hampered me any). There are far more positives than negative.
      05-23-2010, 06:28 PM   #14
RBull
thank you.
      05-23-2010, 07:50 PM   #15
Skelekitty
Skelekitty's Avatar
42
Drives: '07 Imola Red Z4 MCoupe
2007 M Coupe  [10.00]
Yep. We DO love them!
Long discussion here: http://www.zpost.com/forums/showthre...=367909&page=2
and here: http://www.zpost.com/forums/showthread.php?t=368118
~Krissi~ '07 Imola Red Z4 MCoupe
Eisenmann Sport Exhaust | RE X-Pipe | RE Transmission Mounts
      05-23-2010, 09:24 PM   #16
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Good links^
I will be giving strong consideration to the 235/265 combination.
I like the effective gearing change & as long as fronts and rears are changed the same amount, it should keep the DSC happy.
& in the Star Specs, the 265s are 4lbs. lighter than the 275. (28 vs 32)
Edited 4/2/10 @1.20pm after my discussion with Tire Rack--just sharing what they told me--I don't claim it's "correct".
If you do, we're going to hate it as too! I think you'll be fine!
This is exactly what we decided to go with: 235/40/18 in the front and 265/35/18 in the Star Specs. (50 buck rebate on those from Tire Rack as well.)
The overall diameter both front and rear is going to be about 1/2" less than stock, which we went into this knowing and which may have the following effects:
  • A slight increase in effective gearing (which should be fun ) Tire Rack confirmed this
  • Probably a very slight drop in highway MPG (oh my, the EPA mileage police may come after us ) Tire Rack confirmed this
  • Possibly a slight bit more stiffness in the sidewall (which may offset 10mm wider rubber on the stock wheels). Tire Rack confirmed this but recommended running 2 PSI higher as there's less rubber/air cushion [shoulder wear potential with stock PSI] and to increase hydroplanning resistance
  • Potentially more resistance to hydroplanning than the 245/275 setup (from what I've learned, going to wider rubber increases the chances of this, and given the amount of rain we get we took a more conservative position....)
    Tire Rack confirmed that this is an issue with wider rubber--with moderate increases it can be offset with a slight PSI increase
  • Tire Rack also confirmed the suggestion by many here to dial in some negative camber on the fronts to both help with wear with this setup, decrease understeer, and improve turn-in.
I know I could have gone the 245/275 route, or 235/255 (couldn't get the front and rear diameters to be close enough), but this seemed to be the best solution for our needs and objectives.
Thanks for the great input! It made working through the options a lot easier. I'll give an update after they're mounted and broken in.
Thanks Jeremy!
      05-23-2010, 09:49 PM   #17
Skelekitty
Skelekitty's Avatar
42
Before joining this board I knew that tires were round black things made of rubber that made good road surfaces after they had run their useful life on a car. I'm going to have to give up my girlie card if this automotive edumacation keeps up.
p.s. Installing my new Ultimate Pedals with upper left heel-toe extension next weekend - I think I'll go put on some makeup and curl my hair.
      05-23-2010, 09:52 PM   #18
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ you'll love the pedals, had them on my 06 M roady,
I can't wait to get a set on this car.
Tip on installing;
Wedge a block behind the clutch & brake pedals so that they are solid when drilling.
      05-24-2010, 01:48 AM   #19
Skelekitty
Skelekitty's Avatar
42
Tip on installing;
That's smart. I'll remember that!
