06-21-2010, 09:29 AM | #23 |
Rep 323
Question from manual again.
When coming to a stop, is it bad to hold the clutch all the way down and light press on the brake til complete stop, then pop it into N, or should I first pop it into N? |
06-21-2010, 09:49 AM | #24 |
Rep 1,143
If I see a stop light ahead, I typically coast in gear until I need to start braking, at which point I clutch in, brake, and shift into N all about the same time. My clutch doesn't stay depressed for longer than the half second it takes to shift into N.
06-21-2010, 06:28 PM | #25 |
Rep 36
Depressing the clutch doesn't hurt it. That's what the clutch is for. When approaching a possible stop I brake first, thus using a little engine braking; I may even downshift for more engine braking. And I leave the shift lever in place until I'm sure I won't want to accelerate. Only then will I move the lever to neutral and take my foot off the clutch.
06-22-2010, 08:25 AM | #26 |
Rep 4,365
I, too, usually move to neutral. This answer depends on what part of the world you are from though. In the UK they are taught at each stop they have to pull the ebrake (after stopped), the pedal brake is not good enough. As it was explained to me it is to minimize forward motion should you get rear ended... didn't make much sense to me.
I don't ever use the ebrake unless on an incline. I brake in neutral, although some will say not to in case your brakes go out you still want to be able to stop, that is a very rare occurance and I would not worry about it.
06-22-2010, 09:52 AM | #27 |
Rep 146
Yeah i agree with Hawkeye about the U.K. We're taught at every stop apply the handbrake (ebrake) ONLY..... NO FOOTBRAKE and in neutral and wheels in the direct ahead position (if your wheels are already turned to make a turn and your rear ended you will shunted into oncoming traffic). I got a ticking off from my driving instructor for doing the above AND sitting with my foot ON the footbrake, i explained if i'm rearended most likely the rear off the car will lift and being the rear axle is the handbraked end, nothing will be left to stop the car traveling forward. Basically i was told to shut up and he's the "expert".
In my opinion NEVER knock it out of gear and coast to a stop. Brake first still in gear and before coming to a complete stop, clutch in. Coasting at any speed relies just on the cars brakes to slow and stop its entire weight. Slowing and stopping the car when in gear, uses the natural engine brake, resistance of the transmission and rear axel to help the process. In traffic look at everyones road manners, anticipate the road ahead,if you see a brake light ahead lift off the gas, use the engine brake, even come down the gears if the situation allows. The above is MY opinion, i aint preaching. Anybody that has a license from whatever country has passed that countries criteria and can drive legally. jnkhan82, pm me the next time your off, i will see if we can meet up, wanna see you car anyhow, sounds the twin off mine lol. No word on the plates??? |
06-22-2010, 12:35 PM | #28 | |
Rep 4,057
First, I was always taught to use the foot brake only while the car is in motion. The emergency brake or hand brake as some call it, was reserved for use when one parks the car. Second, its darn good practice to keep your wheels pointing straight while stopped waiting to make a turn across oncoming traffic. As Flying Scotsman noted, if you are rear-ended, you may end up being pushed into that oncoming traffic, and the results could be disastrous. Cheers!!!!
Huz-Z
06-22-2010, 02:45 PM | #29 |
Rep 146
Sorry Huz maybe i didn't explain that correctly in my post " when the car has STOPPED, you then apply the handbrake (ebrake) EVERYTIME", parked, waiting to turn, at lights etc etc,,,,not when in motion.
06-22-2010, 07:56 PM | #30 | |
Rep 4,057
Wouldn;t it be awkward ans slow to disengage the handbrake, such as when a traffic light changes from red to green? Cheers!!!
Huz-Z
06-22-2010, 11:19 PM | #31 | |
Car Geek
3621
Rep 3,591
It is all about looking ahead and using all your limbs for car control - that is the way driving skills are taught in the UK. |
06-23-2010, 07:22 AM | #32 |
Rep 238
I have to agree using the hand brake sitting at a light seems like a bad choice, using 4 brakes vs 2? Id rather use the 4. What about for autos, is it the same?
06-23-2010, 07:51 AM | #33 |
Certified Adrenaline Junkie
42
Rep 1,325
Not to mention the lack of brake lights for approaching cars from the rear. I mean, how am I supposed to notice the car is stopped while texting my BFF, drinking my starbucks and chomping down my double double with cheese and side of heart attack?
06-23-2010, 07:56 AM | #34 |
Rep 4,057
All joking aside, the lack of brake lights while using the hand brake only is a significant concern.
Huz-Z
06-23-2010, 08:45 PM | #35 |
Rep 146
06-23-2010, 08:46 PM | #36 | |
Car Geek
3621
Rep 3,591
Never noticed as many rear-ender crashes in the UK as there are in North America, so I assume using the handbrake while stopped at traffic lights as people do there doesn't significantly affect the number of crashes. |
06-23-2010, 08:47 PM | #37 | |
Rep 146
06-23-2010, 08:57 PM | #38 |
Car Geek
3621
Rep 3,591
06-23-2010, 09:08 PM | #39 | |
Rep 146
Where is it you belong in the U.K.? |
06-24-2010, 06:52 AM | #40 | |
Rep 4,057
Good point!! I guess that I always assume that the other drivers are complete blithering idiots! So, I figure that if they don't see my brake lights, they will assume that I am about to move, or that perhaps the car has already begun moving. Back in my bike days (1977 Yamaha RD400 - did anyone say WHEELIE?), I read that the majority of bike accidents were caused by inattentive drivers who did not see the bike. I adopted the view that I was invisible, and that if a driver could see me, he might try and get me (don't laugh, I know one fellow who experienced that). Anyway, all this contributes to my view that other drivers are "mo-rons" and having your brake lights on while stopped is the best plan. Cheers and safe driving!!!
Huz-Z
06-24-2010, 06:55 AM | #41 | |
Rep 4,057
I could tell by your accent!!
Huz-Z
06-24-2010, 08:33 AM | #42 | |
Rep 4,365
I don't know if I agree about the "higher standard" in Europe, I believe it is just different. I think the safer driving comes from your intolerance of cell phones, makup, food, etc etc etc while driving. People over here are just stupid and USUALLY put driving as a second task over what they are really trying to accomplish. The sad thing is I see very few people on the road that put driving as a first priority while on the road.
06-26-2010, 03:24 AM | #43 | |
Car Geek
3621
Rep 3,591
