05-26-2018, 10:44 AM | #1 |
Rep 17
thumping noise on slow/tight turns
Anyone experience this before with their m coupe? Only getting these thumping sounds turning 180 degrees in a parking lot setting. Car was aligned recently so that shouldn't be an issue.
05-26-2018, 11:20 AM | #2 |
Rep 4,057
I had a similar problem years ago on my Z4 3.0si. While my car has a different steering rack than your car, I fixed it by tightening the bolts on the strut braces in the engine compartment. It’s worth a try on your M - just be careful not to over tighten. Someone here may have the proper torque for this.
05-26-2018, 09:41 PM | #3 |
Rep 758
Try backing in a circle clockwise and counter clockwise and see if you hear the thumping. If it's an issue with a control arm bushing this will accentuate the thumping significantly.
Top Down 365
05-27-2018, 02:40 AM | #4 |
636
Rep 3,124
Coming from the front or the back?
The LSD will grump and groan a bit, it's just doing what they do.
05-30-2018, 01:20 AM | #5 |
Rep 133
if its like a grinding kind of sound coming from the rear on tight left/right turns then its most likely the LS diff... I use to get grinding/binding sounds when taking tight turns just after starting up the car... If i drove a few miles for everything to warm up and then tried doing any tight turns, the sound would be faint or gone... i guess this was because by then the oil would have properly shot up everywhere and lubricated the diff after a few miles... This is how you can test if its the diff... Start the car up, drive it about half a mile and then drive around in tight circles, you should be able hear the sound... after that drive the car for a few miles; Highway is preferred to get everything all nice and lubricated then stop somewhere and try to do tight turns to see if you hear the sound... if the sound is no longer present after the highway run, then its definitely your diff...
I ended up rebuilding my diff with new timkin Bearings, seals and BMW oil with FM booster and now there's no more funny sounds.. I've experenced this on 3 M Cars : E86 M, E85 M and my brothers E46 M3 and i rebuilt all 3 diffs with new seals and bearings to resolve the issue. Hope this helps, see my journal for more details..
05-30-2018, 09:25 AM | #6 |
Rep 12,565
What others said, if the sound is from the rear it’s most likely the diff. Uneven tires or alignment settings will probably make it worse. You can always throw in some friction modifier if it bothers you enough.
05-30-2018, 10:08 AM | #7 | |
Rep 3,004
Strut Braces
Racerbruce
05-30-2018, 10:14 AM | #8 |
Rep 326
same; I torque'd one brace to 25 ft-lbs and my noise went away
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
05-30-2018, 11:18 AM | #9 |
Rep 4,057
I'm really hoping I'm right - not because I have a need to be right - but because its the cheapest and easiest issue for the OP to fix.
Huz-Z
MinneapolisJeff8.00 ZAR4MC93.00 |
05-30-2018, 12:41 PM | #10 |
Rep 17
Yes it's actually more of a grinding sound than thumping now that I recall. LSD argument makes a lot of sense although it sounded like it was coming from the front than back. But then again, i am sitting right on the rear axle so maybe it was coming from the rear. I'll try making some tight turns after car is fully warmed up. Thanks for the replies.
