      04-24-2010, 09:32 PM   #1
Spreadsheet
Drives: Black 2007 Z4MC
Hankook Rs-3 tires, anyone else tried them? I really like them alot.
[Same as what I wrote in an autocross post, but thought might start a new post here for more folks to see.]
Has anyone else but me tried the new Hankook Rs-3 tires? They are AWESUM with tremendous grip and not a bad ride on the interstate. Recently took a 130 mile trip and would grade them about 10% noisier than stock, so really a non-issue for me. Maybe 10% stiffer, hard to decide a grade, so not that big a change.
I have a loop I take everyday on the way to work and IF I can get a clean run, used to take it at 50-55mph with the stock Contis and ride a drift all the way around. I do not have a clue as to how fast I can take the same loop with these tires. I popped in at 65+ the last night and it was rock solid. Having to re-calibrate my brain as this is a tight 25mph loop and attempting to hit it at 70+, which I believe these tires will handle, it messes with you at the turn in. Once you;re in the loop it's okay, just the enterance messes with me. I will get over it
Anyway, awesum tire and 245/40/18 and 265/35/18 fit just fine on the stock rims with zero rubbing. Car does have a little "head shake" over some roughness with the tires, but that's it. If you've cycled, not an issue, might be for someone who hasn't.
Take a chance and go for it.
      05-08-2010, 01:37 PM   #2
Spreadsheet
Wow, 80 views of this thread and not a single comment. So do I take this as no one else but me has tried this new Hankook tire?
If so, you are really missing out on a great tire. Have about 1K miles on them and appreciate them more each day.
      05-08-2010, 07:33 PM   #3
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
I've tried the rs2's and they were great so I'm sure these are an improvement
most likely my next tires...thanks for the review
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      05-08-2010, 07:51 PM   #4
mimsterzx7r
mimsterzx7r's Avatar
Drives: 07 M Roadster, 03 Pathfinder
Are these tires more extreme than the Hankook Ventus V12s? I was thinking about picking up a set of V12s for my next set but I may have to look into the RS-3 as well.
ZHP knob/Zeckhausen CDV/ESS Tune/More to come
      05-10-2010, 06:15 PM   #5
Spreadsheet
Yes, much more extreme, basically a R compound tire for the street. Only 7/32nd of inch of tread vs. normal 11/32nd of inch for more new tires. Think of the V-12s as more of a high performance 4-season tire and the Rs-3s as an all out summer R performance tire.
I've been out once in a light rain and traction was very good. Will have to see how they cut through a heavier rain sometime.
      05-13-2010, 11:54 AM   #6
digitalcassette
Drives: 2007 Z4 3.0i
I'm picking up some Hankook V12s early next week. They had some great reviews online.
