09-18-2009, 06:40 PM | #1 |
Rep 352
High Performance Ignition Coils...?
I was browsing the latest Bavarian Autosport catalog and read about their "High Performance" ignition coils. I know that Bavarian Motorsport's version are one of many, but has anyone gone through the trouble of replacing them? Any recommendations and do you have to do anything with the ECU?
http://www.bavauto.com/shop.asp Bavarian Autosport High-Performance Ignition Coil Set - Set of 6 Thanks, Dave
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP |
09-18-2009, 07:19 PM | #2 |
Rep 145
I can't see how you would get $260 worth of performance out of those unless you have some significant mods including higher compression that might take advantage of, or require a hotter spark.
09-18-2009, 07:52 PM | #3 | |
Rep 352
Someone mentioned OKADA Projects Plasma Direct coils, but at $1199 I could just stick with stock and put that money towards a Turbo or Supercharger down the road. Since I'm not having any issues I may as well leave things alone for the time being. Thanks!
09-18-2009, 08:12 PM | #4 | |
Rep 145
09-23-2009, 11:30 PM | #6 |
Rep 4,726
Upgraded coil are for very heavily modified cars, of which the 335 is not even able to be yet. For instance It's a solution for when you are running so much cylinder pressure that the spark dies and you start getting misfiring. Instead of running a tighter gap you can put coils in. It's a tool not really bolt on horsepower (despite advertisements), but horsepower can be gained from utilizing them as a tool.
