09-10-2020, 07:07 AM | #1 |
Rep 399
Headlights lenses
Finally somebody did it, found headlights lenses replacement for our cars
Ideal for folks who doing retrofitting or have edje developed micro cracks https://www.aliexpress.com/item/4000994946822.html
Powered by
09-14-2020, 11:08 AM | #3 | |
Rep 50
You would have to bake them in the oven so the glue becomes pliable, remove the lens, reinstall the new ones. Vids on youtube. Most headlights are sealed, and not clipped on like they are on E46 BMWs. |
09-14-2020, 07:25 PM | #4 |
Rep 69
The z4 headlights are not gluded, but sealed with permaseal. They have to be cut open. Baking, unfortunately, doesn't work on this model. You can break permaseal, but its very hard and best left for the folks that do headlights for a living
09-14-2020, 08:54 PM | #5 | |
Rep 342
IMG_4193 by Eamonn Glass, on Flickr |
09-15-2020, 10:21 AM | #6 | |
Rep 50
I was not aware. Thanks for the correction. I would have found out the hard way lol. |
09-15-2020, 11:46 PM | #7 |
Rep 2,547
I've done several dual Halos on Z4s and the lens are permanently glued on and unfortunately can't be baked to remove.
09-16-2020, 07:07 AM | #8 | |
Rep 399
if you carefully destroy original lens during disassembling without damaging housing it's possible to glue back new lens in
Powered by
09-16-2020, 09:10 AM | #9 | ||
Rep 2,547
I never said they could not be removed, I said they could not be baked off. Sure you can break them into pieces and remove them that way, but it will be very tedious and you may will not get all the pieces off, especially where the glue to holding well. You can use a rotary tool with cutting wheel to carefully cut them off and glue the new ones on. For those with bad lens that can't be polished, this may be a good option. |
