      09-10-2020, 07:07 AM   #1
AK72
AK72's Avatar
Drives: 2007 BMW Z4 m Coupe
Headlights lenses
Finally somebody did it, found headlights lenses replacement for our cars
Ideal for folks who doing retrofitting or have edje developed micro cracks
https://www.aliexpress.com/item/4000994946822.html
Powered by
      09-12-2020, 12:25 PM   #2
Clearancediver
Drives: 2004 Z4
Thought z4 headlight assembly was a sealed unit so how do these supposedly work....
Sent from my smart phone...
      09-14-2020, 11:08 AM   #3
1stw0rldpr0blems
Drives: 2006 Z4MC
You would have to bake them in the oven so the glue becomes pliable, remove the lens, reinstall the new ones. Vids on youtube.
Most headlights are sealed, and not clipped on like they are on E46 BMWs.
      09-14-2020, 07:25 PM   #4
tecnicaeleven
Drives: 07 Cooper S / 07 M Roadster
The z4 headlights are not gluded, but sealed with permaseal. They have to be cut open. Baking, unfortunately, doesn't work on this model. You can break permaseal, but its very hard and best left for the folks that do headlights for a living
      09-14-2020, 08:54 PM   #5
eggman51
Drives: 2006 BMW Z4 M Roadster
This was my experience when I customized my headlights. The E85/6 lights are not for an amateur to crack open and replace the lens. The guy who did mine had 10+ years of experience and said these were some of the most difficult headlights he had worked with.
IMG_4193 by Eamonn Glass, on Flickr
      09-15-2020, 10:21 AM   #6
1stw0rldpr0blems
Drives: 2006 Z4MC
I was not aware. Thanks for the correction. I would have found out the hard way lol.
      09-15-2020, 11:46 PM   #7
pungo
pungo's Avatar
I've done several dual Halos on Z4s and the lens are permanently glued on and unfortunately can't be baked to remove.
Name:  AE close.JPG
      09-16-2020, 07:07 AM   #8
AK72
AK72's Avatar
Attachment 2414644
Attachment 2414645
[QUOTE=pungo;26688227]I've done several dual Halos on Z4s and the lens are permanently glued on and unfortunately can't be baked
if you carefully destroy original lens during disassembling without damaging housing it's possible to glue back new lens in
Powered by
      09-16-2020, 09:10 AM   #9
pungo
pungo's Avatar
Have you successfully removed the complete lens this way?
I never said they could not be removed, I said they could not be baked off. Sure you can break them into pieces and remove them that way, but it will be very tedious and you may will not get all the pieces off, especially where the glue to holding well.
You can use a rotary tool with cutting wheel to carefully cut them off and glue the new ones on. For those with bad lens that can't be polished, this may be a good option.
