03-05-2011, 09:58 AM | #1 |
Rep 77
tire question?
I need to replace the rears on my new '06 Z4m ASAP, going with stock size,
the fronts are newish, Conitsport contacts, thinking about Hankooks to save a little $ in case I end up going to 19" in the future Finally the question? Any issues with mismatch fronts and rears? Guy at tirerack said "no problem" since they'd be the same type tire ps any general comments on the Conti's?
2013 328 VERT MSport Grey/Oyster 6MT
2013 Q5 3.0T S-Line white/black |
03-06-2011, 12:24 PM | #3 |
Rep 362
I've always heard that you shouldn't mix brands but never got a definitive answer as to why not. I'm a bit OCD so I would keep the same brand of tires.
03-06-2011, 12:38 PM | #4 |
Rep 250
Drives: '07 Imola Red Z4 MCoupe
I swapped out my stock Contis last year for the Dunlop Direzza Star Specs and never EVER looked back (except to occasionally turn my nose up at the Contis). They're much better street tires than the stock Contis - stickier and not as hard. I'd bite the bullet and buy four new ones - all the same.
p.s. Finnegan will agree with me and then some. I think he's having a secret love affair with those tires.
~Krissi~ '07 Imola Red Z4 MCoupe
Eisenmann Sport Exhaust | RE X-Pipe | RE Transmission Mounts |
03-06-2011, 09:14 PM | #5 |
Rep 2,782
It's not ideal, but I wouldn't throw away two perfectly good tires. I've mismatched tires numerous times. You'll probably use up the new rears before the fronts are worn. Get the Hankooks, accept the understeer, and replace all four next time around. If you don't like the results, replace the fronts sooner.
03-07-2011, 08:33 PM | #6 | |
Rep 483
You could try it for a week and if you find the difference between the fronts/rears too great you could just replace the fronts. I'm curious why nobody has tried BFGoodrich TW KDA2 as a cheap non-runflat. I had them on my Infiniti G35 and loved them. When my current runflats die I'll get them. |
03-07-2011, 09:08 PM | #7 | |
703
If that's not an option then what Pokey said. |
03-07-2011, 09:20 PM | #8 |
M52, M62TU, S50US, S54, S65
75
Rep 569
if you're just thinking about upgrading to 19", there's no reason to switch out all tires if the 2 front ones are still useable. But if you're planning to stick with your current wheels, go for yokohama advan ad08, it'll excel any other tire meant for street/track.
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT 1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT 2002 E39 540i Protection |
04-09-2011, 05:28 PM | #9 |
Rep 3
Toyo Tires
I went with Toyo T1R tires after test riding several friends cars and the normal internet due diligence. Ride and road noise is a vast improvement over the OE Bridgestones. Since I changed over from run flats, I bought the ContiComfortKit from Tire Rack for confidence to keep in the trunk.
Price is higher than the Hankook, but those tires are real low end round bricks I don't think you would be happy with. Save them for your uncle's oldsmobile, not a vehicle like our Z4s. Mainly I am really enjoying the improved handling with the Toyo's. Tires have tons of grip and are very predictable. When they do break away at extreme cornering, it is smooth and progressive, so recovery is easy. Haven't had a tank-slapper-on-four yet. |
