06-12-2011, 01:38 PM | #1 |
MMA fighter and F1 test driver
18
Rep 362
Apex 18x9.5" et35 sq setup
Hey guys, I know you prob heard this before, but what do you think of:
1) 18x9.5" et35 255 vs 18x9.5" et35 265 all around for the z4M? 2) Does anyone have any experience with this setup? 3) Is a spacer definitely needed and or camber or will I be fine with stock suspension? 4) Does this look weird from the front of the car? Thanks again for all your help.
NOW:08 M.Coupe SMB #102/248 #1669/1815
:|MORRVS8|APEX8|SS.X-pipe|SS.PW.Loop|AFE.intake|Matte.grill|short.ant|Z HP.knob|interior.LED|bulletproof 09 Audi Q5 THEN:96Accord|98Camry|04TSX SC|06 M3|06A4|05Civic Si|05Imprezza|05S2000|08FJ |
06-12-2011, 04:11 PM | #2 |
Commander
221
Rep 850
Drives: Z4MC/M5/640iX/M1000RR
Shereef_Osman was running the 9.5" Apex squared setup with 265s for a while.
The fronts won't fit with stock suspension/camber without rubbing. And you'd need a serious amount of camber up front+spacer to prevent rubbing especially with a 265 tire. Check this thread under the "Squared Setup" section for other possibilities. http://www.zpost.com/forums/showthre...highlight=apex The coupe in the picture is running 9.5" with 265 tires. Last edited by Daemonblitz; 06-12-2011 at 04:16 PM.. |
06-12-2011, 07:00 PM | #3 |
18
Rep 362
thanks dude, damn I wish they made the 9" or 8.5" wheel more concave, it's prob the only reason I don't go with the normal setup.
06-12-2011, 08:33 PM | #4 |
Commander
221
Rep 850
I definitely feel for you, i was in the same boat as you a few months back and wanted concave fronts as well. I ended up going with 9" fronts and 10" rears, the most aggressive you can go on on stock suspension/camber.
06-12-2011, 10:16 PM | #5 |
18
Rep 362
thanks dude, so how are the 9" rims in person? Does the difference in concavity between the fronts and the rears bother ya?
