      03-10-2013, 12:29 PM   #1
Golfboy
Drives: 2008 Z4 3.0si Coupe
Fuse # for windshield washer fluid sprayer
Can anyone advise what number fuse controls the windshield washer fluid sprayer. I have a leak that I can't find the source of and I would like to just pull the fuse that controls it. I looked at the fusebox but unable to determine which fuse it is. Thanks in advance for any help in this matter.
      03-10-2013, 12:39 PM   #2
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
#40 controls the headlight sprayers
      03-10-2013, 12:49 PM   #3
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
#40 only controls the headlight sprayers, not the windshield.
OP, I would seriously doubt pulling the fuse can eliminate your leak as the pump is already in its normal OFF position.
      03-10-2013, 12:51 PM   #4
Golfboy
Kgolf31,
Does fuse #40 also control the windshield washer sprayers that are on the hood for the windshield? I don't have headlight washers on my car.
      03-10-2013, 02:33 PM   #5
Golfboy
XMetal, I think my leak is with the windshield washer reservor. It keeps running low and I have been refilling it to keep the yellow warning light from coming on in the dash. I'm tired of doing that and thought that I could eliminate the windsield washers completely by removing the reservor but then the light will stay on in the dash unless I can pull the right fuse. But I don't know which fuse to pull. That is my problem. Hopefully someone knows which fuse it is and can advise me.
      03-10-2013, 03:02 PM   #6
Kgolf31
Kgolf31's Avatar
460
Originally Posted by Golfboy View Post
Kgolf31,
Negative, only headlight washers
