Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > USA - California
      08-16-2010, 02:02 AM   #1
brandobot
Drives: 06 Z4M
Installing clutch delay valve on z4 - bay area Anyone in they bay area
Anyone in they bay area able to help me install
or modify my current CDV on my z4?
http://www.zeckhausen.com/cdv.htm
      08-18-2010, 10:33 AM   #2
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
My car shop can do it. They're BMW and Mercedes certified maintenance shop, but not a factory "indy" shop by any means. However, I've been going to them for servicing my '04 325Ci, '91 MR2 Turbo, and now the '07 Z4MC. As well as my family's cars as well. I've also had them help me with tons of aftermarket installs and fixes too (mostly for the MR2, as I've tracked that car quite a few times in the past two years or so). They charge really low labor rates for me and my buddies that need stuff done. They can do a lot of things, from engine rebuilds to transmission rebuilds (next door shop), some body work (contracted bodywork guys), basic maintenance items such as oil & filter changes, fault code readouts, tire mounting/balancing, some batteries, etc.
They have shop discounts for tires and even OEM equipment items. Otherwise, you could go aftermarket, in which case it's even cheaper. It all depends on the item at hand, and what car you're servicing.
I usually go in there to borrow their lifts and tools, etc. =P
The shop is called JK Auto & Repair. It's located in Campbell if you're interested.
      08-18-2010, 02:27 PM   #3
brandobot
Drives: 06 Z4M
Thanks! I will give them a call!
      08-18-2010, 02:33 PM   #4
mfanatic325
///M-fanatic
Taiwan
193
Ask for Kao (pronounced kinda like "cow") and tell him Lon sent you
      08-18-2010, 02:39 PM   #5
mfanatic325
///M-fanatic
Taiwan
193
My buddy is actually going to be helping with me eventually. I'm planning on taking the CDV out soon.
For you though, I figured you'd want the labor to be done somewhere that can offer you warranty, etc. so I didn't mention my friend, but JK Auto instead
      09-03-2010, 03:33 AM   #6
mfanatic325
///M-fanatic
Taiwan
193
lol I ended up taking the CDV out myself. I brought the car to the shop I referred you to, but they were busy that day, so I ended up just borrowing a lift and some tools and did it myself in < 30 minutes
Having access to a lift and shop tools makes things SO much simpler
      09-03-2010, 11:16 AM   #7
brandobot
Drives: 06 Z4M
Did you replace the CDV valve with a new modded one? Or did you mod your OEM one? I'm open to anyone doing it as long as they're mechanically inclined and know what they're doing.
      09-03-2010, 03:33 PM   #8
mfanatic325
///M-fanatic
Taiwan
193
I just removed the OEM one. There's really no need to put a replacement one in unless you're that scared that the dealer might find out and try to void any warranty. But honestly, who's going to think about looking at the CDV, let alone know what the CDV is
