      08-03-2013, 04:15 PM   #1
604skyline
Drives: 2020 M2 CS
wheel help again; ordering custom bbs e88 from europe need optimal widths/offsets
ok for starters, I am in on the ohlins group by, so a full suspension will be coming to be, provided that ohlins is still going to do this!!
now, i am going to order a full custom set of bbs e88 direct from europe and I get to pick widths/offset and custom colour if desired. my question is what are the optimal widths/offsets that everyone on here would recommend?
do I go 18x8.5 front and 18x9.5 rear?
or do I go 18x9 front and 18x10 rear?
now with offsets; I can honestly pick any.... with 8.5 front do I go et35 or little less, the 9.5 rear et22 seems perfect?
now if i go slightly wider do I get less offset or keep it the same?
would like to hear everyones thoughts and like I say, these are going to be built to whatever specs I choose, so I can nail down exact offset!
**tire size help would also be appreciated!
      08-03-2013, 04:31 PM   #2
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
either way you can fit just as much tire if that is what you are looking for...apex has good offsets for fitting wide tires. I have ec-7's in 18x9.5 +35 and 18x10 +25....I am pretty low but with a reasonable drop you can fit 275s and 245/255s
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      08-05-2013, 03:17 PM   #3
604skyline
Drives: 2020 M2 CS
thanks for the reply.
I am looking for some more specific help with regards to what offsets to choose? does anyone have any insight? They are totally custom so I can choose what I need.
is 18x9 front and 18x10 rear for widths too strong?
I know that the volk te37sl; has some pretty ideal sizes at 8.5front et35 and 9.5rear et22 should I just get those specs on the e88?
      08-05-2013, 03:42 PM   #4
dorifto88
Drives: 88 Nissan Pathfinder
imho, and unfortunatly ive been through a few sets of wheels. width of 9 to be safe, 9.5 if you want to run some camber. in the rear, 10 is safe, 10.5 with a little camber, 11 if you just want to say you have 11's. the best fitment wheels i have EVER had on this car are the arc 8s, front was +35, rear was something like +25. ymmv, lots of variables though. best wishes
      08-05-2013, 03:44 PM   #5
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
This wasn't specific enough for you? I run this setup as well...
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      08-06-2013, 07:18 AM   #6
DRedman45
DRedman45's Avatar
35
Are you asking for e88 specs? This is the wrong forum for 1 series specs if you are, if that's the case you will be looking around 8.5 +45 front and 9.5+60 rear
My Build Thread
      08-07-2013, 04:36 AM   #7
Gt4
Gt4's Avatar
Drives: 2006 E46 M3 Estoril blue 6mt
He is looking for a BBS E88 (track wheel only)
http://www.bbs-usa.com/race-wheels-d...?CLID=62&WF=12
I would go 18x9.5 et35 18x10 et25
      08-07-2013, 03:10 PM   #8
beta
Drives: 2006 M Roadster
What is your usage of track versus street?
      08-07-2013, 03:27 PM   #9
Drives: M2 Comp
^WHS
      08-10-2013, 01:02 PM   #10
604skyline
Drives: 2020 M2 CS
Guys thanks for all the help so far. I forgot to clarify originally, these are purely for the street, the newer/latest iteration of these wheels are perfectly acceptable for street use and a ton of porsche guys, 993 and on use them on the street.
so they are purely for aesthetic purposes as I just like the look of them...
so for beta and intgr8r hopefully you can assist.
thanks again gentlemen.
