      04-09-2013, 09:01 PM   #1
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Better performance with AC on?
Floridian heat has sapped a butt dyno estimated 20hp from my car, compared to driving it in Philly. Whats odd, is that recently I've been driving it with the air conditioning on, and it feels like I have more torque.
The supercharger kit is very ambient temp sensitive with how the car feels. Its not decreasing in performance with time (heat soak), but feels stronger or weaker with as little as a 10* temperature variance.
I've heard some 911 turbos run faster with the AC on, because of how the AC lines are routed. Could it hold true for the Z4M also, or am I just being crazy?
      04-09-2013, 09:59 PM   #2
seank
enthusiast
seank's Avatar
48
Sounds crazy but I've heard crazier, so you are probably normal.
      04-09-2013, 10:04 PM   #3
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
WTF? How does the AC have to be routed in order to actually have performance gain from using it?
We know that:
1) AC runs off of the crank, so it saps a tiny bit of power as-is when in use
2) AC generates heat with all else equal
Please enlighten me on the other variable(s)
      04-09-2013, 10:10 PM   #4
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
The ac compressor turns off during full throttle...
      04-09-2013, 11:36 PM   #5
ZStig
279
MAGIC
      04-09-2013, 11:38 PM   #6
ZStig
279
We know that:
On the 911, the engine bay is very tight, and I imagine the cold AC lines might be near the intake manifold. Maybe I'm thinking of another car, but its something my mind recalled.
I've also always felt like the AC took away power, but maybe its helping the supercharger somehow. Very small chance, logically speaking, but I'll definitely try it on/off on my next dyno run
      04-10-2013, 01:40 PM   #7
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
AFAIK the AC compressor is belt driven and has a clutch, which closes when you turn your AC on, otherwise the pulley is free-wheeling. I doubt the lines running the refrigerant have any cooling effect on under-hood temps.
      04-10-2013, 02:19 PM   #8
Beedub
Originally Posted by yousefnjr View Post
AKAIK the AC compressor is belt driven and has a clutch, which closes when you turn your AC on, otherwise the pulley is free-wheeling. I doubt the lines running the refrigerant have any cooling effect on under-hood temps.
+1
      04-10-2013, 03:18 PM   #9
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
The lines only get cold after the expansion valve/evaporator (which is located in the cabin heating unit). Before that they are ambient.
Only the lines after the evaporator might be coldish. The evaporator tries to absorb as much heat as possible though.
Everything else is hot in the ac system, and judging form the size of the average condensor there's a fair amount of heat to be dissipated (and gets both under the hood and directly heats the radiator (which is usually placed behind the condensor).
I think the only better performance with ac on is coming from the driver who can keep a cool head
      04-10-2013, 03:29 PM   #10
GriffBrew
Drives: 2006 M Roadster
Maybe gas without ethanol? I've seen mileage increases in other cars after leaving Florida, not sure if there are performance increases too.
      04-10-2013, 04:16 PM   #11
ZStig
279
Thanks for breaking it down for me, my mind must be playing tricks on me
      04-10-2013, 06:24 PM   #12
3002 tii
3002 tii's Avatar
2286
I route the AC back to the intake
Follow for latest mods
      04-11-2013, 09:18 PM   #13
ZStig
279
sweeeet
      04-11-2013, 09:22 PM   #14
gtMc
gtMc's Avatar
21
Drives: '08 MC
'03 e39 m sport  [0.00]
'08 mc  [0.00]
really. ? i want to see it.
      05-29-2013, 07:59 PM   #15
Gallardo Rosso
Drives: 2007 Z4M Coupe
I noticed a modest boost in highway MPG with the a/c on in 50-60 degree evening temps. Looking to repeat the experiment in 90 degree daytime heat. Also, my thermostat (gauge on dash) reads low around 180 when full warm... Maybe some correlation.
      06-11-2013, 06:45 PM   #16
Punko
Drives: 07 Z4 M Coupe
Originally Posted by ZStig View Post
MAGIC
I liked that way too much.
      06-11-2013, 08:04 PM   #17
ZStig
279
Its funny re-reading it for me now
      06-11-2013, 09:07 PM   #18
mfanatic325
///M-fanatic
Taiwan
193
I'm sure it was entertaining for everyone
      06-12-2013, 12:16 AM   #19
StickMon
StickMon's Avatar
Drives: 2006 MR
I notice that my exhaust note sounds a lot better with the air on.
(Because it's working harder to run the compressor)
Maybe it just sounds torquier with the air on.
      06-13-2013, 03:04 PM   #20
davesz4mc
Drives: 2007 z4mc
Go to the dyno!
Maybe the added load% remaps fuel/vanos to a diffrent map?
2007 Z4MC, 1" drop H&R Springs, Evolve Tunning, Headers, K&N Filter, RPI scoop, Red top high energy coils, UUC Red Poly mounts (none bolt-through), UUC Lightweight Flywheel with Organic Clutch and a custom exhaust with just one AeroTurbine muffler.
      06-15-2013, 05:07 AM   #21
The__J__Factor
The__J__Factor's Avatar
Australia
88
Drives: ///M Coupe
Ac steals power. when I dynoed my m it was only like 2hp difference but still a loss.
      06-15-2013, 10:02 AM   #22
ZStig
279
thanks for the confirmation
