      03-30-2011, 02:59 AM   #1
jimmyage
Drives: Z4M R
Question Z4MR 2007 - Startup issue
Hi Guys!
Never posted on this forum before, but i have read alot since christmas when i bought my Imola Z4 M Roadster. My god what a beast, i had a E46 M3 before but i dont think you can compare the two
So to my problem:
The car runs fine, except for som idiling issue and a rare startup problem. It takes maybe less than a second more to start than normal, i know this. Ive had it in authorised BMW dealer 2 times and they cant solve the "problem". They upgraded the software last time but nothing changed. Still takes a little to long to start the car.
Im so annoyed at BMW for just reading the electronics and if no problem comes up, the car is perfectly fine.
So Do you guys know what this can be?
Please help!
BR,
Jimmy
      03-30-2011, 07:41 AM   #2
Shipkiller
Shipkiller's Avatar
Drives: Me
How do you park your car?
I have the same issue (very intermittently) if I park the car overnight on a grade. This does not normally happen when parked on a level surface.
Does not really bother me. I consider it an idiosyncrasy of the car..
      03-30-2011, 08:45 AM   #3
Swanicyouth
Drives: Z4M
I had a stalling issue when starting in temps below the 30s. I solved it by putting the key in the on position a few seconds prior to cranking. It seems the build up of fuel pressure prior to cranking is what the M needs on a cold start. If you listen you can hear the fuel pump run and shut off.
      03-30-2011, 09:32 AM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^this is the proper starting procedure.
The fuel pump will start in the first position & pressurize the system.
      03-30-2011, 01:02 PM   #5
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
If it helps any, my car takes a while to start---probably 1 second of it cranking---and I wait for about two seconds at position 2 before cranking.
I think it's normal for our cars. No problems with idle after it starts.
      03-30-2011, 01:05 PM   #6
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
Mine also takes about a second to start, especially in temps below 50 F. I'm parked on a rather steep incline though.
Nikki
      03-30-2011, 01:10 PM   #7
PatJags156
PatJags156's Avatar
Drives: 335i Convertible
What about a "shutter" when turning off the engine? Or an unsteady idle? Anyone have that?
      03-30-2011, 01:31 PM   #8
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
Yeah mine does the shutter at turn off.
Nikki
      03-30-2011, 01:40 PM   #9
PatJags156
PatJags156's Avatar
It's kinda unsettling. There's no way that can be normal.
      03-30-2011, 01:47 PM   #10
wdupdog
wdupdog's Avatar
Drives: Z4
Stutter on shut down, clutch out. Clutch in, shut down, no stutter. Smooth idle all the time.
      03-30-2011, 01:52 PM   #11
PatJags156
PatJags156's Avatar
Shutter no matter what. Doesn't matter when the clutch is in or out.
      03-30-2011, 02:01 PM   #12
wdupdog
wdupdog's Avatar
Drives: Z4
Turn key to running at 1050rpm, 1.2". Then drop to 850 at 1.9" total. 47 degrees in garage.
      03-31-2011, 12:06 AM   #13
VitaminT
Drives: 2006 M Roadster
I have an issue even when letting the pump prime in colder weather <45deg, it was sag below idle and then surge before settling at the normal cold idle. When warm outside no issues. Idle all other times is dead on.
      03-31-2011, 02:06 AM   #14
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
Slow startup IS one of those idiosyncrasies of S54 motors from what I've come to believe via hands-on experience.
I also try to allow the fuel pump some time to pressurize prior to startup. Here's a recording of how long it takes to start
