08-08-2010, 07:39 AM | #23 |
Rep 97
Correct the mounting point of the strut brace at the firewall. I swore mine were tight but they weren't, so if I were you I would just get in there and torque down the braces.
08-08-2010, 06:33 PM | #24 |
Rep 385
Found the culprit... Broken strut brace mount on the driver's side. Verified with a drive down the street with the braces removed; no more noise.
I think I know when it broke; I recently hit a nasty bump on the freeway, which also bent my driver's side front wheel on the inboard side. Anyone know if there'd be any ill effects to driving around with the braces removed for a few days? I won't have time to get that crack welded for another week or so and my M is my DD. Not sure if the un-braced strut towers will flex too much on the crappy roads here in LA, potentially weakening something major.
08-08-2010, 07:03 PM | #25 |
Rep 1,110
I'd say you'd be safe if you stay away from aggressive driving/ potholes and such while they are removed
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
08-08-2010, 07:32 PM | #26 | |
Rep 421
http://bimmerfest.com/forums/showpos...36&postcount=1 |
08-09-2010, 04:34 PM | #28 |
Rep 421
08-17-2010, 08:15 PM | #29 |
Rep 385
Dealer was 100% useless. Had an appointment and they wasted 45 minutes of my time BEFORE telling me there's no way BMW will cover it out of warranty and they won't let a tech peek at it to give even ballpark estimate without charging me $150 first. Worst service writer of all time...
Has ANYONE had this fixed before? I think I'm just going to take it to a local indie shop and have the broken mount welded.
03-19-2011, 04:10 PM | #30 |
Penfold, shush!
Rep 132
The plastic nav in my M buzzes like crazy sometimes, usually under low RPM loads. Engine mount bolts loose, maybe? Strut braces are the old style, but they're German tight.
Thoughts? It's not a rattle. It's literally a buzzing sound. |
07-15-2014, 05:51 PM | #32 |
Rep 1,061
On mine, I found the plastic directly under the dash by the pedals had popped out of it's holder on the left side and would rattle over bumps, 10 seconds to pop it back in place and all is well!
08-31-2014, 01:49 PM | #33 |
Rep 2
Had a rattle on my Z4 which sounded like it came from behind instrument cluster and only occurred when riding over bumps. Sounded like a small tambourine or a loose bag of pencils. I took the dash apart, fitted padding around all contact points but rattle still there. Then I flicked the sun visor back and the rattle appeared. Turned out to be the guide for the roof hook was rattling. This could occur on either side of the car and could be the cause of all of those cannot find rattles. I fitted a small piece of foam and hay presto rattle gone. easy way to check if this is your rattle lower the roof and tap the locking point. Hope this helps...
08-31-2014, 10:21 PM | #34 | |
Rep 1,990
09-01-2014, 01:39 PM | #35 |
Rep 2
Thought I would just share some info but if it taken like this then I don't think I'll bother in future if all on this forum as condescending in their comments !
09-02-2014, 01:20 PM | #36 |
Rep 1,990
Not being condescending. Just pointing out the issue had been solved. Your comment seemed directed to the OP as if he had not figured it out yet. As I said in my comments to you, thanks for adding your info as someone may experience the same rattle you had.
