08-13-2015, 01:47 PM | #67 | |
Rep 54
On the topic of shocks/struts, I see a lot of folks are using Konis as well as Bilsteins. It's pretty unlikely that I'll ever track this car - and I only occasionally push it around. Otherwise it's almost a daily driver and I've been grumbling a bit to myself about the rigidity on my freeway commute. I'm not sure what I should do here - stock, Bilsteins, Konis or something else? |
08-11-2016, 01:28 PM | #68 |
Rep 54
Third oil change and I'm getting more comfortable with the jack stands. This is the only car that I own that has to be jacked up to access the oil plug.
So I pulled the plug and let it drain for at least an hour (ran to Advance for oil and filter and to recycle the used oil). When I removed the filter cap, it had enough pressure to overflow the housing, which was a PITA to clean up. Some went between the alternator and the head, and, well, there's no easy access back there... So is that normal to have some pressure in the filter housing? I was surprised by how much residual oil was in there after draining for an hour. |
08-11-2016, 02:34 PM | #69 |
Rep 1,923
I usually find e46 DIY when I can't find for the z.
Some are pretty similar or same. Congrats on your new car. Good choice!
08-11-2016, 02:42 PM | #70 | |
Rep 54
Oh, I should point out that is is a resurrected thread. I've had the Z for almost 2 years now. Sorry about that. I just updated with this question:
08-11-2016, 03:43 PM | #71 | |
Rep 2,866
08-15-2016, 04:16 PM | #73 |
1821
Rep 5,337
Crack open the filter last.
Open oil fill cap (on top of engine). Open drain plug and drain. Crack open oil filter cap, let sit. Remove filter. If oil spills out of the filter even with following this order, something is wrong.
08-15-2016, 07:24 PM | #74 |
636
Rep 3,124
^WHS
Fill cap, then drain, then open filter. I've done it about 20 times now, and the filter canister is maybe 1/2 full with the filter still in it.
08-17-2016, 01:09 PM | #75 |
Rep 54
Ok, maybe I just haven't let it sit.
What possibly things could be wrong? It should have a free route to the oil pan, right? Or is the pump between the pan and the filter? I drained at least 5 quarts out of it before opening the filter cap, so I know that it's eventually getting back down there. |
10-30-2017, 02:07 PM | #77 |
dances with roads
4732
Rep 4,096
10-31-2017, 06:19 PM | #78 |
Rep 239
Very different. The 535 has the n54, which is a biturbo engine with aluminum block. Z4 is n52, normally aspirated with magnesium-aluminum block. The 08 528 has a very similar engine to the Z4.
