02-24-2013, 03:05 PM | #133 |
Rep 2,138
Drives: Me
Looking at the pictures, they appear to be centered, not offset. I know this works because one or two others on the forum have done this.
Before I jump, I just want to know all the variables so I can plan for the unexpected. . |
02-24-2013, 03:43 PM | #134 |
Rep 11,667
...not powerflex.
The ones I ordered are out of the UK and are offset. Check here... http://www.superflex.co.uk/proddetai...od=SF095-2558K & here http://www.ebay.co.uk/itm/BMW-Z4-M-O...30855932966%26 Last edited by inTgr8r; 02-24-2013 at 03:52 PM.. |
02-24-2013, 04:11 PM | #135 |
Rep 2,138
Drives: Me
Now those look good.
A little pricy but 'you have to pay to play'................ . |
02-25-2013, 06:12 AM | #136 |
Rep 1,546
Getting exciting hearing a little progress on this thread. Thanks Intgr8r for being the guinea!
03-04-2013, 05:00 PM | #137 |
Rep 11,667
The bushings just arrived.
The quality looks 1st rate. Install is still a little ways off, but I'll take a couple of pics with measurements when I get a few minutes. I'll start a new thread so that it's easier to find later on.
03-06-2013, 12:11 PM | #138 | |
Rep 102
03-06-2013, 12:16 PM | #139 |
Rep 11,667
^ good to know there's a vendor on this side of the pond.
03-07-2013, 01:03 PM | #140 |
Rep 855
I think I'm going to talk to Treehouse Racing about making a Z4M control arm bushing
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
03-12-2013, 04:02 PM | #141 |
Rep 855
So I didnt talk to Treehouse but I did end up talking to Condor Speedshop (vendor on R3V) and they are interested in making a Z4M polyurethane FCAB
2014 335i M Sport
04-02-2013, 05:28 PM | #144 |
Rep 11,667
Should have mine installed in the next couple of weeks as well.
04-06-2013, 03:53 AM | #145 |
Rep 5,329
do these just press into the Control Arm??? Having a quick look the Crontrol arm looks like an easy piece to remove so a simply DIY?? or am i missing something... would like to jump on these soon :-)
04-06-2013, 09:03 AM | #146 |
Rep 11,667
Yes they are a direct fit.
I think You will need a proper setup to press these yourself though. ....might be easier to just pull off the bush and have them done.
04-06-2013, 09:40 AM | #147 |
#buildnotbought
10871
Rep 4,895
I think you only need a small workplace press? Maybe 15 tons or so (they cost only about $200 and every workplace should have one imho)? That's usually enough for the biggest bushes (especially when only pressing in is a must; removal can also be done with a small grinder and stone, grinding through the old metal bush)
04-21-2013, 10:49 AM | #148 |
#buildnotbought
10871
Rep 4,895
So? already installed?
There is also a variant on this superpro bushing. http://www.bavauto.com also has an 66mm offset bushing It 's used (like the superpro) in normal z4/3series to change the caster angle. And I think this one will maybe also fit the stock z4m It's currently on sale (clearance item so stock is limited) for like $7/piece I can't post a link (java site) but it's Part # : N52606BAV If you select a 2004 z4 3.0i you can get there through the menues (It won't list with another car it was not intended for)
05-10-2013, 06:35 AM | #149 |
Rep 22
Installed. The shop had no problem installing the new Super Flex bushings. Completed track event at Summit Point (main). The car was much better behaved under hard braking.
05-10-2013, 12:19 PM | #151 | |
Rep 11,667
I kinda got side tracked with the DKF group buy. Maybe I'll get these on this weekend.
05-12-2013, 01:13 PM | #152 |
Rep 11,667
Finally got these installed & glad I did.
When I got into it, I found that both of my OE FCABs were done!!! Both of them had split the rubber along the narrow side of the offset. This is definitely a weak spot on the OE FACBs. It makes sense since there is just not much rubber to flex, so it tears. I tried to get a couple of pics but split rubber just didnt show up well. I did jet a pic of the finished job though..... Looking forward to a test drive
05-12-2013, 02:59 PM | #153 |
Rep 5,329
05-12-2013, 03:24 PM | #154 |
Rep 11,667
Not bad....
Biggest problem is getting the old ones off. .....easy if you have a puller though.
