      06-15-2014, 01:34 PM   #1
rsutoratosu
Drives: Z4 3.0i
Uh oh. E85 brakes
Got all the brakes done. Bleeding driver front. Bleeder screw broke off
Looks like my option is drilling it out or new caliper.
Anyone have any extraction ideas for a bleeder screw?
-Roranji
      06-15-2014, 10:16 PM   #2
JPWEraser
Drives: 2016 Corvette Z06/Z07
http://www.sears.com/craftsman-7-pc-...2&blockType=G2
Has come in handy more than once. Should work well.
      06-15-2014, 11:14 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
      06-16-2014, 09:10 AM   #4
rsutoratosu
Drives: Z4 3.0i
have any better ones ? i had those, i was removing a strip screw from acura door and it destroy those bits. I like to get a set made from adamantium if possible
-Roranji
      06-16-2014, 09:16 AM   #5
JPWEraser
The torque on those bleeders isn't much and (obviously) it's a softer material than something like a door mounting screw. I've not had a problem using mine.
      06-18-2014, 08:40 AM   #6
rsutoratosu
Drives: Z4 3.0i
that is correct, they're like 15 pounds or something right ? i gotta find my sheet.. i will try it out
-Roranji
      06-19-2014, 05:31 PM   #7
Gallardo Rosso
Drives: 2007 Z4M Coupe
You should be able to get it out. A screw extractor set like above and some gentle heat is your best bet. If you can carefully drill the ID of the bleeder larger you could use the next size up extractor. Be careful of the heat brake fluid is flammable.
Worst case scenario remove the caliper from the car and carry it into a competent mechanic/ machinist. They should be able to make quick work of it.
      06-19-2014, 07:12 PM   #8
rsutoratosu
Drives: Z4 3.0i
so far first extractor failed. just tried it 5 min ago. the grabit pro extractor just keep shaving the screw out.. didn't grab anything. waiting for the longer flute extractor thats coming tomorrow.. hope that one works.
-Roranji
      06-19-2014, 07:34 PM   #9
ssummers
Drives: 2005 Z4 3.0
Even though the torque isn't much on those, there is a tapered seat that seals it off. I suspect it is seized to the taper. Heat will help break it loose, I would remove the caliper, remove the fluid from it, and judiciously heat what is left of the bleeder. An easy out should work at that point.
      06-23-2014, 10:59 AM   #10
rsutoratosu
Drives: Z4 3.0i
the screw got striped out some.. I have a new caliper coming so i'll just use this as backup.. haha.. so once the new one is here, ill take this one out and probably rebuilt it and save for next time.
-Roranji
