07-27-2011, 12:47 PM | #45 |
Rep 1,002
The warranty and free maintenance services for my 2007 Z4MC is expired in a week. The odometer is at 24,918 and Service indicator is 8,475. I don't know how the Service interval gets calculated but it seems vary quite a bit. I put about 7k miles since is bought the car with a lifetime MPG of 21.8. Not sure if the computer was accidentally reset since the battery was replaced around 18.5K miles. Is there anyway to find out?
07-27-2011, 04:49 PM | #46 | ||
Rep 283
07-27-2011, 05:26 PM | #47 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
07-27-2011, 07:19 PM | #48 | |
Rep 1,002
Thanks in advance for all the feedbacks and to the OP I don't mean to threadjack. |
07-27-2011, 07:36 PM | #49 | |
M = Midlife Crisis
65
Rep 2,006
07-27-2011, 08:30 PM | #50 |
Rep 1,002
Thanks Caddyshk. I will try and hopefully they will do something for me. This is my first BMW so i don't have any connection with the local dealer.
07-28-2011, 07:11 PM | #51 |
Rep 283
inspection.pdf
Dropped my MC off yesterday morning at 9 and got it back around 2PM today. Here is a cut up copy of the receipt they gave me. qty? - part num - description 1- 11427833769 - oil filter 6 - 07510009420 - oil 1 - 11127832034 - cylinder head cover 6 - 11127831271 - (other) cylinder head cover? 1 - 11347832282 - Valve Timing Gear - Cam Shaft/adjusting plate 3 - 11347832282 - Valve Timing Gear - Cam Shaft/adjusting plate 2 - 11347832283 - Valve Timing Gear - Cam Shaft/adjusting plate 6 - 11347832284 - Valve Timing Gear - Cam Shaft/adjusting plate I'm guessing they did the valve adjustment? Instead of a copy of the paper with each valve reading on it they gave me a copy of the checklist (emailed to me). The car felt like it ran a lot smoother, but maybe that's just from driving the Sebring for a day? When I got in my car I noticed the wires that go to the shift knob were cut and also hanging out of the boot. When I bought the car the shifter came off pretty easily and the wires would come out so I thought this was normal, but they looked like someone clipped them with wirecutters. Service rep said everyone there denied cutting it but regardless it was under warranty so a brand new knob is on it's way. I was pretty happy with this new rep as he seemed to know a little more than the other guy, plus Im getting a shift knob that won't fall off. Does everything look kosher to you guys? ps, dont' know if it's part of the inspection, but they also flushed my brake lines. |
07-28-2011, 09:07 PM | #52 |
Bad Lieutenant
233
Rep 3,517
I don't know why your shift knob would be touched, but those parts are related to an adjustment needed. The car must have cooled quickly, I believe the TIS specified < 35 degrees C for the coolant before the valves may be checked.
07-28-2011, 09:35 PM | #53 |
Rep 283
? They had it a day and a half, i guess they did it this morning.
07-28-2011, 09:46 PM | #54 |
Hug the road... Carpe Asphalt
106
Rep 722
Phishman...
Would you mind sharing how much they charged for the valve job - parts and labor? Thanks!
2007 BMW ///M Coupe
07-28-2011, 10:28 PM | #55 |
your average JAMF
3160
Rep 4,101
My car is at the dealer right now, 2 weeks before my 4/48 expires. I'm having a cowling under the windshield replaced (it's cracked and warping), my 2-yr brake fluid flush done, and the goo bottle for the mobility kit replaced.
When I had Inspection I done 2 years ago this month, I always suspected that the valve adjustment hadn't been done, or hadn't been done right. I dropped the car off at 8am. It was ready at noon. My receipt shows the proper oil & filter and a a couple of gaskets, but NO sign of the valves being done. The only descriptive text is "PERFORMED INSPECTION I PER CHECKLIST B54". So today when I dropped the car off I asked my SA (new as of my last visit) to look into this, explaining that 4 hours from drop off to completion isn't possibly enough time to do the valve adjustment, considering that the engine needs to cool, and the work itself (not to mention the rest of the stuff that goes with Insp I) can't possibly be compressed into that time frame. He called me back at noon to say they were keeping the car overnight, as both the cowling and goo had to be ordered and will be in tomorrow. No problem, I have a nice '10 328i as a loaner. As for the valve adjustment, he spoke to the "shop foreman", who assures him it was done. He tried to leave it at that, so I asked what about the time frame issues? He said they have a big fan that they point at the motor with the hood up, and get them cool in about 2 hours, have "always done it that way, never had a problem". What a load of BS! Even if that were true - that only would leave 2 hours to do ALL the Insp I work, including valves - NOT POSSIBLE. Does anybody have an SIB or other documentation of the time they are supposed to allow an engine to cool, or other supporting documents I can shove in their snouts? I'm extremely irritated. Don't even get me started about the 3-4 times they've overfilled my oil, or the 2 consecutive visits where I got the car back with 40 psi in all the tires, and was told "they do that to all of them" when I complained about it. That's Jiffy Lube BS, not what we should expect from one of the largest BMW centers in the USA. Sheesh.
'21 M2 Comp
'19 Golf R |
07-28-2011, 10:54 PM | #56 | |
Bad Lieutenant
233
Rep 3,517
07-28-2011, 10:54 PM | #57 |
Bad Lieutenant
233
Rep 3,517
Yeah, man, sorry, got your car confused with someone else who suspected the service time was too short.
07-28-2011, 11:17 PM | #58 |
Rep 421
07-29-2011, 12:50 PM | #59 |
Rep 283
07-29-2011, 01:56 PM | #60 |
106
Rep 722
I think you mean "Maintenance"?
So let me think this over... My car is a CPO till 8/31/2013. Currently my dealer offers their BMW extended maintenance (6yrs/100k) for $2500 on top of the CPO. Would this valve check be included under the extended maintenance program - once I hit the due mileage? I know the brakes (pads and rotors) are. So this may be worth to pay for, as long as I am guaranteed to recieve both the valve job and brake job within the extended maintenance period. Anyone knows?
2007 BMW ///M Coupe
07-29-2011, 03:05 PM | #61 | |
Rep 283
07-29-2011, 03:24 PM | #62 |
106
Rep 722
Yes I will hit 25k easily within the next 2 years. Is the valve job included in the extended BMW maintenance plan?
2007 BMW ///M Coupe
07-29-2011, 03:47 PM | #63 |
Rep 283
I would recommend asking your dealership just to be sure, but I have seen some members on here claim it is covered and is worth the cost because of how much the inspections are.
07-29-2011, 03:52 PM | #64 | |
Rep 1,269
2019 Porsche 911 4 GTS
07-29-2011, 05:39 PM | #65 |
M = Midlife Crisis
65
Rep 2,006
Supposed to be all scheduled maintenance...
07-30-2011, 07:51 AM | #66 |
106
Rep 722
I checked with my dealer:
Inspection I (which includes the valve job) is part of the scheduled maintenance (in my case ~9200 miles to go (according my ODO - so at 25k miles)) and if I purchase the extended maintenance plan ($2495, tax included, not maked up (per SA statement) and no discount), it will be at no charge. If I have the dealership do it outside the maintenance plan, it's close to $1500 for inspection I (-/- 10% for being a CCA member). The valve job takes 4 hours. My brakes are no-where near showing signs of brake-pad wear, lots of meat left (I checked it with my SA, he took a flash light and showed me the brake-pad side walls). I doubt I need a brake job within 10k miles, currently I have 16k miles and tons of life left (and original tires with pleanty of threat). So is it worth to purchase the extended maintenance assuming I will need Inspection I, 2 oil changes, 1 brake fluid flush, 1 cabin filter and 1 set of wiper blades in the next 2 years? On a side note: is the statement that the rotors last 2 sets of brake pads correct? Or do they both need changing at the same time?
2007 BMW ///M Coupe
