      04-03-2011, 12:39 PM   #1
850tgul
850tgul's Avatar
280
Drives: 718 GT4, F87 M2, F30 330xi, X3
One more for magnaflow (with vid and part numbers)
Hi All,
Like many others I wasn't willing to shell out a grand for a set of aftermarket mufflers. Through some trial and error, I sucessfully got some maganflow cans and tips installed and couldn't be happier. I had these fabbed up with flanges so that they bolt and unbolt just like the stock cans. Mufflers are universal magnaflow non-polished part # 11365 2 1/4" pipe. They were the smallest I could find to give the exhaust guys enough room to play around with. At first I tried 2 1/2" pipe cans, but they didn't work. Tips are C5 corvette tips that the shop provided. The issue is, if you wish to use the flange and not cut into the stock pipe, the lack of room when the dual tips are added. The corvette tips were short enough to work and I think they look great on the MC.
Impressions-Very happy, slight drone around cruising speeds but barely enough to even mention, a non-issue really. Overall the noise is very stock like, a bit deeper in tone, just turned up about 30%. I would characterize this setup as mild to moderate, the wife even approves. If you can, check out the clips through real speakers.
      04-03-2011, 01:06 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
sounds pretty good down low
      04-03-2011, 02:31 PM   #3
dorifto88
Drives: 88 Nissan Pathfinder
sooo many thanks for the part numbers ! i plan to do this after i get back from my vacation
      04-03-2011, 03:00 PM   #4
gatorfast
gatorfast's Avatar
Drives: 718 Cayman
Agreed. Sounds mean down low...not so much in the upper rpms.
      04-03-2011, 03:02 PM   #5
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
im convinced.... it sounds good.....I bet if someone mass produced this it would sit well with many owners
      04-03-2011, 03:23 PM   #6
ZStig
279
it IS a mass produced, universal muffler
      04-03-2011, 03:44 PM   #7
r4gs
Viper Driver
Singapore
36
Drives: F-16
thanks for posting a video and review. the magnaflows sound like they've got a great, bassy tone, but like aforementioned, the higher rpms sound really raspy. how much was the entire setup including installation?
      04-03-2011, 06:47 PM   #8
tekmoe
tekmoe's Avatar
55
Drives: ///M
Awesome. Magnaflow FTW.
BTW, mine are also the same 11365 mufflers. Most likely the only ones that will actually fit up under there without being too long.
      04-03-2011, 07:07 PM   #9
850tgul
850tgul's Avatar
280
As far as the rasp yes, when the car is parked and revving in neutral, you do hear that metallic rasp, but only around 7 or 8K rpm. I have yet to hear it while driving, no matter the rpm, and I have red-lined it. Under load it just sounds deep and mellow, no rasp.
To me there are basically two kinds of exhaust sound, a rumble (that chambered flowmaster sound) and a booming sound. Now these magnaflows are pretty straight through, so the sound is more boom than rumble, but nothing like a civic, it is deep and mellow most of the time.
I paid $390 total for this setup ($140 for the mufflers and $250 to the shop, which included all labor and the tips).
Also forgot to mention, no loss of power at all (I had feared a straight through design would equate to less back pressure and less torque down low, but no).
Very happy with how it turned out.
      04-04-2011, 09:31 AM   #10
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
someone with some welding skills, fab up some flanges and tips to these magnaflow cans and make a group buy!
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
