      02-27-2012, 08:20 PM   #1
Starscream
Starscream's Avatar
Drives: ///M Roadster + E92 335i 6MT
Built my own 3M Sun Gun for under $40 :)
10% of the original cost of a 3M sun Gun I have the exact same thing except I had the fun of building it myself lol
OK so for those NOT in the know, What the bloody hell is a 3M Sun Gun?
Well,
I'll show you,
http://3mcollision.com/3m-pps-sun-gu...kit-16400.html
Its a cordless light that is widely known to the detailing community to be the best swirl finder money can buy,
Sadly these little buggers come with quite the price tag,
The retail on them is around $400,
To me that is ludicrous for a light,
So I decided to make my own following various other detailing enthusiasts ideas,
So where to start,
Well Firstly you need a 12v Cordless Drill, and 12v is very important,
18v is too high for the bulb, 14.4 is ok but 12 is ideal,
So First you need the 12v Drill,
Then you need the exact same bulb that's in the 3M gun,
The Solux 4700K Daytime light,
Then you need a holder for this light and then its pretty much plug and play,
I'll walk you through my steps,
First the drill,
a wonderful absolutely nothing wrong with run of the mill 12v Skil Drill,
(even came with its own case)
Next the Solux bulb and connector,
After which you open the drill,
and then take out the motor and chuck,
Test fit the bulb in the chucks grooves,
and wire the 2 very simple wires that come from the trigger to the bulb connector
Of course now would be a good time to test it before you put it back together,
Great!
Now simply put the case back together and your left with something that should look like this
and it fits nice back in its case with room even for a spare bulb!
Ok so now on to some test shots (I know they are not the greatest)
Firstly a badly swirled Ford F Series Pick Up,
Next a Chevy Malibu in a sad state
Finally my other BMW *smug* * smug* with no swirls a deep gloss
Hope you guys like it,
I was even thinking of wrapping the Skil red case in carbon fabric material lol,
Even though the first thing you think is that this bulb will melt the housing your wrong,
It gets slightly warm to the touch, but never hot, You don't really have it on for more than 30 seconds at a time anyway, Its not a flashlight, Its a swirl spotting light, Even though it will light up a room better than any flash light I have ever seen lol,
I was thinking of going the extra mile and adding a small computer fan so blow on the back of the bulb but it really doesn't get that hot,
Not sure how many detailers we have on this site but its pretty cool to me,
Imola Red Roadster
      02-27-2012, 09:17 PM   #2
Twisted Six
Twisted Six's Avatar
Drives: Z4si-coupe
Nicely done DIY. Makes me wish I didn't throw away all those 12volt drills when the batteries became weak.
      02-27-2012, 09:20 PM   #3
Starscream
Starscream's Avatar
Something always comes in handy after you have thrown it away!
This little bugger is a new unit that I got for a stupidly low price I didn't feel so bad breaking it up
Imola Red Roadster
      02-27-2012, 10:11 PM   #4
007MCoupe
007MCoupe's Avatar
Drives: '18 Sakhir M3 ZCP
Awesome! Love the DIYers out there that come up with this kind of stuff!
      02-27-2012, 11:09 PM   #5
WestCDA
Drives: 2006 Z4R 3.0si
Nice job! Amazing how that bulb fit into the existing chuck holder grooves in the drill housing - you'd think it was made for it!
      02-27-2012, 11:41 PM   #6
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
That's awesome.
I use 2 500w Halogen Stands, but they don't really help much on the roof, hood and trunk. I have to depend on a smaller 250w bulb and fluorescents.
I may have to do this
      02-28-2012, 12:45 AM   #7
Barryb97
Drives: 2006 M coupe
Awesome! I'm going to do it!
      02-28-2012, 05:53 AM   #8
Starscream
Starscream's Avatar
Originally Posted by Kgolf31 View Post
That's awesome.
Yup I set those up as well for when I'm polishing, But for close ups and to check your work something handheld is always great,
and 3M's gun is known as the best of the best and I've always wanted one,
I just couldn't justify the price, so I made my own lol,
Its the exact same spec bulb as 3M use too,
Imola Red Roadster
      02-28-2012, 05:56 AM   #9
Starscream
Starscream's Avatar
"most" drills will accommodate a MR16 bulb just fine,
I've seen people put them in a bunch of different drills, mostly over at detailingworld.co.uk,
British site, But then again I am a Brit lol,
Just most of the drills they use are not available in the US so I had to do some searching for one over here that I could use,
and even though its a good thing, for this project its not, but most handheld powertools are 18v now,
Rare to see a 12v anymore,
Imola Red Roadster
      02-28-2012, 09:07 AM   #10
WestCDA
What is the diameter on that MR16 bulb? I could do a quick 'snout' measurement to make sure it would fit, if I happened to run across a cheap 12V donor drill ...
      02-28-2012, 10:38 AM   #11
Starscream
Starscream's Avatar
Its in the drill so I dunno,
Sure google can pop up dimensions of the bulb,
Imola Red Roadster
      02-28-2012, 11:09 AM   #12
WestCDA
I saw you had a spare in your case (perhaps it was just the box from the original), so thought it might be handy to check. I found this info online - it looks like it's a 2 inch bulb:
The number after "MR" indicates the diameter of the bulb in eighths-of-an-inch. If you are using an MR16 light bulb, your bulb is 2" in diameter.
I'll keep my eyes open for a suitable cheap 12V drill kit ...
Cheers
      02-28-2012, 12:12 PM   #13
Starscream
Starscream's Avatar
Cheers
Wow I just face palmed so hard just now,
Imola Red Roadster
      03-01-2012, 04:12 PM   #14
drew935
Drives: Suby
I'm going to give this project a go as well.
      03-01-2012, 06:05 PM   #15
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Very creative.. I love it!!!!
      03-01-2012, 06:13 PM   #16
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
I happen to have an old 12V Dewalt handy!
2006 Z4MC - #LL93158
      03-01-2012, 06:15 PM   #17
BIMMERGUY91
Drives: 2014 335I M Sport
nice i will make myself one of these very soon
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
      03-02-2012, 03:31 PM   #18
santov
santov's Avatar
64
Drives: 2007 Z4 3.0si White over Beige
This is awesome! I love the resourcefulness of our community!
You should post this over on autogeek.net/forums. They'd go ape over something like this.
Thanks for the DIY!
      03-02-2012, 04:06 PM   #19
Starscream
Starscream's Avatar
I'm always buying stuff from autogeek,
Didn't even know they had a forum lol!
Love this little light
Imola Red Roadster
      03-05-2012, 09:12 PM   #20
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
where did you find the pig tail socket for the bulb?
[edit]
NM ...found it
[/edit]
      03-05-2012, 11:13 PM   #21
Shorestyle031
Shorestyle031's Avatar
39
Drives: 08 M roadster
What's wrong with a flashlight, what makes this so much better? Real question not trying to sound like a di*k
08 M roadster
      03-06-2012, 09:47 AM   #22
E86Z
Drives: 3.0si
The light from the sungun can replicate the effect of the sun hitting your cars paint, that's generally where you see the most swirls or spider webbing. Basically its a very strong concentrated light vs the dispersed light of a flashlight (someone chime in if I'm way off lol).
More info here:
http://www.detailingworld.co.uk/foru...d.php?t=202530
There are a bunch of threads about it there.
