      11-18-2014, 11:34 AM   #1
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
apex lug kit 75mm or 90mm
hi guys, finally decided to pull the trigger on one of the apex lug conversion kits, but I am at a loss which kit to choose..
I am running 10mm spacers, will the 75mm be long enough? or do I need to go the 90mm?
thx in advance guys.
Powered by
      11-18-2014, 11:36 AM   #2
RobMCoupe
RobMCoupe's Avatar
60
Drives: 2007 Z4 M Coupe
75mm will work up to 12mm spacer. I was looking at them too, but decided to wait on it.
      11-18-2014, 02:59 PM   #3
jdoublehcubed
Mechanical Engineer
Drives: 2006 Z4MR, Imola Red
I would recommend the 90mm so you have flexibility on wheel spacer selection later.
I got mine from Rotiform, I think they had an 85mm size that was a nice option.
      11-18-2014, 06:06 PM   #4
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
I ran 75mm when I still tracked my car. Front stuck out a wee bit but the rears were flush.
      11-18-2014, 06:21 PM   #5
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
This is correct - I have 75 mm studs with 12 mm spacers. Keep in mind the longer studs will stick out further. If you have to run huge spacers, you need different wheels IMHO.
      11-18-2014, 09:36 PM   #6
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
75mm it is then guys, thx
      11-19-2014, 07:54 AM   #7
3002 tii
3002 tii's Avatar
2283
I also got extended lug nuts with my stud
Follow for latest mods
      11-21-2014, 01:19 PM   #8
Beedub
these apex studs... be warned, a guy on m3forums had a a complete set on 1 wheel sheer off on a 2 month old set..... He pm'd me detailed info on what had happened and they basically failed, no impact , not 1 snap but the whole set on 1 wheel, i found this very concerning.
more than happy to dig up the thread......
      11-21-2014, 02:12 PM   #9
3002 tii
3002 tii's Avatar
2283
Unfortunate thing is threads like those are not unusual, and there's never a definitive answer as to why it happened. There are so many variables, many pointing to if the user installed them correctly. With that said, I have used Apex, Bimmerworld and VAC studs. The reason for so many is because I replace them every 2 years. But loctite + proper torque (which is a lot less than one would think) + reasonable replacement intervals and you should be good to go.
      11-22-2014, 02:40 AM   #10
Beedub
solid response as always my friend, i completely agree with you, it is strange that the bolts we replaced never had such issues ???
i have studs too and i think I'm due to replace them. I've done 3 years on them, around 8 track days now. but the failure rate on studs is MUCH higher than the stock bolts we are supposed to upgrading... something isn't quite stacking up for me.
      11-23-2014, 11:53 PM   #11
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
listening intently to Dub and tii...
Powered by
