04-03-2018, 12:12 PM | #1 |
Rep 158
Drives: 07 Z4 M Coupe
S54 Vanos Exhaust Hub / Vac Motorsports??
I'm having my Vanos refreshed this month with the Beisan upgraded parts including the re-drilled pump disk.
I'm hoping that my exhaust hub tabs are in good shape but want to be prepared in the event they are damaged. In my numerous searches I see that there are several options and I have read up on them. One that I don't find much info on is the Vac Motorsports hub. Does anyone have any experience with it? From what I see it appears to be a well made part. I do see that there are quite a lot of M3 guys that don't care for the company. I just want know if this is solid option or not. If the hub does need to be replaced what would you recommend? Thanks! |
04-03-2018, 02:14 PM | #2 |
636
Rep 3,124
Sure looks pretty, and cheaper than the TurboToy C300 hub that I have.
I would say go for it.
WhatTheFetch92.50 |
04-04-2018, 08:46 AM | #3 |
Rep 199
I came across the vac hub recently as well, and will be going with it when the time comes to refresh my vanos system. You will not need the re-drilled pump disk if you're taking this route.
WhatTheFetch92.50 |
04-04-2018, 12:31 PM | #4 |
Rep 453
Drives: 2007 Z4M Coupe
Wow, didn't even know about this. Seems like a better solution than the Beisan re-drilled holes. This way you get the tighter clearance to the pump disc and a beefy tab. Price seems more appealing than the turbo toy. I might go this route. Curious to hear from those who have installed this.
04-04-2018, 06:59 PM | #5 |
Rep 158
I'm considering just going with it and returning the Beisan pump disk. Seems to me it would be better to replace the oem hub that is known to fail. I just can't find where anyone has actually installed it or really any info other than their website. It really does look well made..
04-05-2018, 12:14 AM | #6 |
Mechanical Engineer
96
Rep 1,025
looks like the same concept as the turbotoy hub, except that it looks like its made from one piece.
my biggest concern is that if they're manufacturing it themselves, they may not get the splines exactly right, especially the heat treatment of that area of the part. those splines are, by an order of magnitude, the hardest part to manufacture. i like that the C300 hub reuses the BMW machined splines. i used a C300 hub when mine needed replacement. on the other hand, i think VAC are pretty competent people, i've been to their shop in person and came away impressed. they have a real focus there on the S54 and other BMW engines of that generation, so they probably know them better than most other BMW shops. |
WhatTheFetch92.50 |
04-05-2018, 09:54 AM | #7 | |
Rep 2,866
WhatTheFetch92.50 |
04-05-2018, 05:06 PM | #9 | |
Mechanical Engineer
96
Rep 1,025
if the tabs are already broken then get the C300 hub. there are hundreds (low hundreds) of people using those without issues. |
WhatTheFetch92.50 GuidoK10845.50 |
04-06-2018, 08:05 AM | #10 | |
Rep 158
Great point, I don't see any reports of failures after having the redrilled disks installed and I know that there a lot of them on the road. Last edited by WhatTheFetch; 04-06-2018 at 04:22 PM.. |
04-06-2018, 12:17 PM | #11 |
Rep 870
Drives: 2006 BMW Z4M Roadster
How much would you expect a shop to charge to drill the holes? I would just be concerned with precision. If it isn't exactly 180 degrees from the existing holes, it would be out of balance. They would also need to match the depth and chamfer the edges of the holes if they match OEM and what Beisan does. If they goof, that's an expensive part to replace outright. Not disagreeing that it could probably be done cheaper, but there would be some additional risk.
04-06-2018, 01:21 PM | #12 | |
10846
Rep 4,892
C300 maraging steel is an extremely hard and tough type of steel, mainly used in aircraft so that the part can be made as light as possible, whereas the vac hub is made of 4340, which is a more common/ordinary type of steel, but also heat treatable. I wonder what the main reason is why that exhaust hub breaks. Is the stock steel used too soft (weak)? Is it too brittle? or is it more a fatigue thing (s/n curve)? So should the main reason for using a type of steel be the hardness/tensile strenght or for example results from an impact notch test? Any hardcore steel experts here that really know what theyre talking about ? In the end how controlled the hardening process is carried out is also a factor that determines the end result. The turbotoy hub for sure is the most tested one. I think they also went from a more common steel to the maranging steel (its in its 3rd version of development/material choice)
StickMon636.00 |
04-11-2018, 11:36 PM | #13 | |
Mechanical Engineer
96
Rep 1,025
04-23-2018, 11:51 AM | #14 |
Rep 158
Fortunately my hub was intact so I ended up going with the Beisan Pump Disk and it is definitely a lot quieter than the oem disk. Mine really had a rattle at 2500 to 3500rpms.
I had the work done with Kevin or "Kaiv" over on the M3 forum. He really does know is way around the S54. He rebuilt the Vanos with all the Beisan goodies including their upper chain guide, also did a valve job and some other fluid maintenance items and I couldn't be happier. He kept me informed during the process. Afterward he provided pictures of all the work, included a write up with the parts list and also pointed out a couple items that will need attention down the road. If anyone has an S54 that needs a little TLC in the San Diego area I would surely recommend him. |
04-22-2019, 10:40 AM | #15 |
Rep 51
Exhaust Hub
I wonder what people think about this - if the existing exhaust hub is intact, is it sufficient to just upgrade to the Beisan pump disk and leave the stock exhaust hub, or is it necessary to upgrade both the pump disk and the exhaust hub in order to help prevent the tabs from breaking in the future? Would that be an over-kill? I'm trying to decide if it's worth saving the money.
SOLD - Daily 09 335xi AT- VRSF 7" FMIC, VRSF DPs, VRSF DCI, VRSF Lower CP, ER upper CP, PTF Tune 93 octane, 19" Bayern, Pirellis, LUX H8 160.
2001 Z3M Roadster S54. Black on Black. Completely stock. |
04-22-2019, 11:38 AM | #16 | |
Rep 2,866
04-22-2019, 03:12 PM | #17 |
Rep 51
Thanks, that is helpful to know!
