04-14-2018, 10:19 PM | #1 |
Rep 61
Help, new top, won’t close, getting frustrated.
Took old top off, new top on, all bolts are roughly in but it still is about two inches from closing when it finishes it’s cycle.
Could a cable be in the mechanism? Can someone please help |
04-15-2018, 10:03 AM | #3 |
Rep 2,704
Not real helpful here, but...
Could the fabric need to stretch? Can you help the pump close the top by pulling it into place for those last few inches??
04-15-2018, 12:33 PM | #5 | |
Rep 2,704
Letting it warm up would definitely help
04-15-2018, 04:03 PM | #6 |
Rep 5
When I got a new top on my Z3 the installer said it would be tight for a while until it stretched. She recommended several wet/dry cycles to help it loosen up. It closed easily after a few weeks and has always been leak free for 4+ years. The Z4 top is is thicker, with many layers, and may be a different proposition to break in.
04-15-2018, 07:12 PM | #8 |
Rep 758
Yes, they are that tight initially. It might take a day or so to get it to where it will make it to the windshield frame, possibly longer if the weather is cold. When I did mine that was about where it stopped initially. I helped it go a bit farther and then let it sit like that overnight. The next day I backed it up and then helped it move forward again and the gap closed to about an inch. I let it sit like that again overnight. Next day it got almost to the windshield frame and I pushed it the rest of the way by having the wife press the top button while I applied pressure on top of the front of the top. That got it to the windshield frame and then I had to push forward from the inside to get the alignment pins into their sockets and get it latched down. Once you get it there leave for 4-5 days before you try opening it again. You may still have to give a bit of a push to get the alignment pins into their sockets for another week or so but after that you should be good to go. It will all depend on if you can get some sun on it to warm the canvas.
Top Down 365
