04-17-2012, 01:44 AM | #1 |
Rep 204
painting the key hole
I have considered painting the key hole black/matte black to match the rest of the car since the silver/aluminum sticks out like a soar thumb. Has anyone painted the key hole or covered it somehow to make it look like the other side? I've searched for this topic, but had little luck finding anything. I have a 2007 bmw z4 coupe 3.0si....THANKS!
04-17-2012, 07:07 AM | #2 |
Rep 153
i know there are caps you can buy for them... i need to do something to mine also, might go the plastidip route since i never actually use the keyhole...
04-17-2012, 07:44 AM | #3 |
Rep 112
Just after you cover the key hole, you will have an electrical failure that will require you to manually unlock your car (at least that's my luck).
04-17-2012, 07:56 AM | #4 |
Rep 1,987
This place: http://www.bumperplugs.com/BPindex.html has "door plugs" which will do what you want and can be removed if needed for emergency entry.
04-17-2012, 12:45 PM | #5 |
Rep 153
04-17-2012, 02:05 PM | #7 |
Rep 296
I have been thinking of removing mine altogether!!!
It is broken so I can't use it if I wanted to =-( I have had to get in the car manually before and I have found if you use the key in the hatch (bottom of emblem) you can reach up and pull the door lock post on top of the door! So no need to even have the door key... |
04-17-2012, 06:49 PM | #8 | |
Rep 204
04-17-2012, 08:54 PM | #9 | |
Rep 1,987
From the FAQ: "I don't drive a Porsche. Will these products work on my car?" Yes. Our original BumperPlugs™ and Door Plugs™ work on just about every make and model. Holes that are drilled into the bumper may have to be enlarged a bit (1/4" is the ideal size), but our plugs will pop right in. Door Plugs may require trimming to fit (do not force) but they do work on many makes and models. In addition, we produce flawless painted interiors and carbon fiber for all highline vehicles worldwide. |
