      04-11-2012, 06:15 PM   #1
wss4
Drives: 2008 Z4 M Coupe
Euro headers EGT codes
I recently installed euro headers. I removed the rear O2 sensors, and the EGT was placed in the same location as the stock US headers. After installing, I got the expected O2 codes, along with an EGT code (2C92) and the SES light.
I then had my DME flashed with Epics tune. The SES light was removed, and I cleared all codes. However, I keep getting the recurring EGT codes (2C92 and 2C93) - EGT electric and plausibility. The car feels slightly underpowered, and is definitely running rich based on fuel consumption (+20%) and the rapid carbon buildup on the exhaust tips. I have contacted Epic regarding this issue and he is certain it is a failed EGT sensor.
I find this odd as I had the car in for inspection II at the dealer less than a week prior to installing the headers, and they did not pull any codes related to the EGT. Does anyone have any experience related to this issue or have any suggestions?
      04-11-2012, 06:27 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
Its possible to burn a sensor immediately after moving them around and the car is still adjusting. Assuming its connected correctly
      04-11-2012, 06:48 PM   #3
wss4
Double checked electrical connections a couple times, no problems there. In the bavarian autosport documentation with codes I have, there are 3 listed for EGT:
2C87 - EGT sensor signal
2C92 - EGT sensor electric
2C93 - EGT sensor plausibility
I initially was only throwing 2C92, but am now getting both 2C92 and 2C93
      04-11-2012, 07:25 PM   #4
beta
Drives: 2006 M Roadster
I don't know, but maybe it expects to have the EGT in the euro location?
      04-11-2012, 07:48 PM   #5
johanness
Drives: 2008 Z4MC
Check the other various threads on this. Only 1 member I know has placed his EGT sensor in the header and had it 'work'. I'm skeptical at best with it in that location. The rest of us have placed it in the stock EURO location without any codes or CEL.
Also, check your gaskets.
      04-11-2012, 08:09 PM   #6
kennyfrc
kennyfrc's Avatar
18
Drives: 2008 Z4MC
+1 it must go on the cat pipe as shown in the diagram. Also even the SLIGHTEST PIN HOLE in your welds will cause a CEL from the post cat O2. Ask me how I know!
Daily: 2010 Tacoma Double Cab
      04-11-2012, 08:43 PM   #7
sabbanick
Drives: 08 SBM M coupe
I had to replace my EGT sensor was throwing same codes and car is now cel free. When I had my EGT sensor in section one pipe I was underpowered. I am running epic tune as well.
      04-11-2012, 08:48 PM   #8
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Wait, so let me get this straight. If you get the SS V2 and have the o2 bungs welded behind the 2ndary cats, you need to put the EGT sensor in the Euro location? Even without a tune?
      04-11-2012, 09:09 PM   #9
sabbanick
99% people running non us headers relocate rear o2 sensors and EGT sensor to section one piping. I have deleted rear O2s and have EGT located on headers.
      04-11-2012, 09:19 PM   #10
wss4
Same setup here. Interesting that you were throwing same codes and needed to replace EGT sensor as well. Did you have any codes/issues before the headers and tune?
Sounds like I'll be ordering a new EGT sensor as per Randy's recommendation, figured I'd get a few other opinions before spending an extra $200.
      04-11-2012, 10:05 PM   #11
sabbanick
No I was actually SES free for quite some time...I recently has to replace bank 2 lambda sensor and EGT sensor though..
Randy is great to deal with hope you are happy with his tune.
      04-11-2012, 10:21 PM   #12
wss4
I do not have an SES light anymore, but still throw codes for the rear O2 sensors and the EGT, so I assume Randy turned off the SES light for those codes. Hopefully the new EGT sensor will keep my car from running so rich and help make the power it should
      04-11-2012, 11:32 PM   #13
sabbanick
Don't think the EGT sensor with throw the SES it is just a "soft" code.
The o2 sensors however threw SES lights...hope you get everything resolved with the car.
      04-11-2012, 11:57 PM   #14
johanness
Drives: 2008 Z4MC
EGT does throw a CEL. You're CEL free because your tune has shut things down. Good to hear your EGT likes it's home up in the headers tho. Must be a SS thing.
I'm curious to relocate my EGT sensor to your location and see if there is extra power to be had, but I'm extremely skeptical. Not sure anyone has tried this on a set of Euro headers before? (Pls chime in if u have).
Either way, I'd like to line up w/u sometime and see what's what.
      04-12-2012, 07:18 AM   #15
onebluemcm
onebluemcm's Avatar
42
Drives: '07 Z4MC
I just want to be sure of what to do when I install my euro headers. A while back I was very confident that this was a mod that would work with no issues. I recently began reading the forums again about it and now I'm more skeptical, seems like a crap shoot if your going to have problems or not.
Theoretically, if I move the o2 sensors behind the section 1 cats and move the EGT to section 1 ahead of the cats, it should work with no codes? Is it better to use shorter O2 bungs rather than long ones? Pics of factory euro section 1s seem to show short, 90-degree bungs.
Just not really willing to have: persistent codes or CEL lights, or problems like increased fuel consumption or less power. I really don't want to be dealing with the latter two issues, kind of defeats the whole purpose of doing this....
<img src=http://i284.photobucket.com/albums/ll30/onebluemcm/RG63_08-1-1.jpg border=0 alt= />
|=.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-.=|
Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY (1 of 3, this combo)
RAC RG63 | Conti EC-DW | GC/Koni-Dinan | Rogue RSM | Arqray | Autosolutions | BMW brace | Pinnacle tint
      04-12-2012, 09:20 AM   #16
wss4
From what I understand, if you are not planning on getting a tune for the car, you will want to relocate your rear O2s and EGT to mimic the euro section one. Many people seem to have done this and are code/SES free. If you plan on getting a tune for the car, I would contact them to confirm that these euro sensor locations will work for their specific tune.
As I have the Epic tune with euro headers, I just removed the rear O2 sensors, and put the EGT in the headers as it was on the US headers. I communicated this EGT location to Randy, and I assume the tune is written to account for that location.
