04-11-2011, 08:41 PM | #1 |
Rep 457
How long before your H&R springs fully settled?
Installed H&R springs on Thursday night. Have driven them a couple hundred miles (albeit almost all highway miles) since then. Really wish these fronts would lower a lot more...
How long till you felt your new springs fully settled? I'm contemplating running the fronts without the little slivers of oem padding there is, but before going through the headache of taking everything apart and putting it back together again I'd like to get some feedback on how long it took for other guys. BTW, on the fronts did you all leave the clear plastic lining on the top few coils in tact or did you remove it? I left it. Figured it was to prevent the coils from rubbing the paint off the adjacent coil and rusting.. curious how much lower my front would be without the little pads and that clear lining.. if I had to guess I'd say 2-4 mm's...
04-11-2011, 09:05 PM | #2 |
instagram 997turbotom
284
Rep 7,377
did you put 15mm spring pads on the back? Otherwise the back will be lower than the front.
I'm putting mine on this weekend, How do you like them so far?
04-12-2011, 07:29 AM | #4 | |
Rep 457
Bah. I don't remember my H&R springs taking this long to settle on my e30 baaaaack in the day..
04-12-2011, 07:55 AM | #5 | |
Rep 11,668
Roffle Waffle is correct, the rear definitely sits lower w/o the 15mm spring pads.
04-12-2011, 08:20 AM | #6 | |
Rep 457
I'd post links but I'm on my phone. And roffle I forgot to answer your question, so far I like them, stiffen things up a little bit but not drastic. If I could get another finger width drop out of the front I'd love them. Think maybe I'll need to throw my 19's on there, perhaps the little camber and un-aggressive oem offset is making it looks worse than it is.
04-12-2011, 08:29 AM | #7 |
Rep 11,668
I've seen them take two weeks to settle on a car that isn't driven much.
If you've put 200 miles on them, you are pretty much settled. FWIW here is my old roady on H&Rs fully settled with the 15mm pads.
04-12-2011, 02:37 PM | #9 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
Fully settled w/o pads on rear. Full tank of petrol. On a flat surface I cannot tell that the rear is lower. This picture is on a sloped DW. Springs took about a week to settle.
Hear are the same springs on my roady(no pad)
2008 Space Grey M Coupe-Euro headers-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap with O2 and EGT delete-H&R Sport springs-Zeck CDV delete-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Uniden R7-H&R front and rear spacers-Alarm module added-stereo amp recoded to vert spec settings |
04-13-2011, 01:03 PM | #11 |
Dark Sider
129
Rep 1,779
I noticed that a while back. They are factory size. In the vert picture I'm running Hankook v12's. 245/40f and 275/35 rear. 18"
04-13-2011, 06:16 PM | #13 |
Rep 457
About to throw the 19's on now. But what made me check this thread was a thought that just hit me: I wonder if the guys with no spring pads and perfect drop have their pins pulled in the front. I'm thinking tbe extra camber may make it a little lower. Am I crazy?
Will report back soon...
04-14-2011, 05:56 AM | #14 |
Rep 725
04-14-2011, 04:17 PM | #15 |
Rep 881
Drives: 95 M3, 15 i3, 17 M3 Frz Wht
This should get you where you want to be, you should double check to make sure it fits our suspension before you order.
http://www.e90post.com/forums/showthread.php?t=476422 btw for my e46 ive tried several springs and they all took a good 2 weeks to fully settle.
04-18-2011, 06:22 PM | #19 |
Rep 457
anyone know if those e46 drop hats will fit??
Thanks buddy. Love her but might sell her in a month or two. Just don't need the payment.. The only semi-clear pic of the duc I have... To stay on topic, the way the coupe sits right now, on a slight decline so it doesn't look as bad... actually even looks good to me in this pic, it's deceiving. Flat surface has slightly reverse rake
04-18-2011, 06:54 PM | #21 |
M = Midlife Crisis
65
Rep 2,006
Confirmed!
2006 Z4MC - #LL93158
