      05-02-2022, 08:21 PM   #1
Nipsey
Drives: 2007 Bmw z4 coupe
Scan tool or software
I have been trying to find an answer regarding a scan tool or simple app/software that can reset or delete transport mode. I can’t seem to find any recent reviews that clearly state if any can. I know the software downloaded to a laptop such as inpa I believe it is called, will work but it is beyond my ability and comfort level. I believe the foxwell 510 did work. Not sure if the latest 530 with bmw software can. I know carly can’t as I have tried that.
Thanks for any help
      05-07-2022, 12:46 PM   #2
Dynamics99
Drives: 2011 E92 & E90 335i 6MT MSport
Should be able to change the mode with BMW Scanner 1.4 since I've done it.
If you don't have it a google search will net you a download link. You do need to have a cable for it though. eBay sells them. The tool is a lot easier than using INPA or ISTA or NCSEXPERT but it has its limits.
Here is the link to a post in the UK forums:
https://z4-forum.com/forum/viewtopic.php?t=126371
      05-09-2022, 02:29 PM   #3
Nipsey
Thank you for the link. Does the program require a laptop or could an android tablet do it?
      05-09-2022, 07:33 PM   #4
Dynamics99
It requires a laptop. For windows, you should be fine as long as you have a USB port. For Macbook, you have to run Windows Bootcamp. I have used a windows laptop but it's so slow that it grinds the gears in my brain. So I decided to install Windows Bootcamp on my Macbook Pro. I will get a USB A to USB C adapter and see if it works. Fingers crossed.
      05-09-2022, 08:16 PM   #5
Nipsey
Thanks for the help
I can try the windows laptop route and if it is to clunky maybe I can beg the wifes mac book
      05-09-2022, 09:00 PM   #6
Dynamics99
Haha,
It should not hog up much memory or processing power compared to ISTA or INPA. You can also code some features on the Z4 using the tool. It's quite rigid I would say. NCSEXPERT is also another tool used for coding (a bit complicated but there are guides).
      06-12-2022, 12:59 AM   #7
Nipsey
Could you offer any advice on installing the software. I am struggling with the drivers I believe. I downloaded the proper drivers for windows 11 which is what I am running. But it keeps stalling, not recognizing my cable possibly. It is a bummer geeks cable which I have used before
      06-12-2022, 07:45 AM   #8
tomjonesBT33
tomjonesBT33's Avatar
Drives: 2006 Z4 M Roadster
Where are you located? There may be a forum member in your area willing to help. If you're in the Northern Virginia or DC metro area, I can reset this for you.
2006 Z4 M Roadster - Silver Grey Metallic
2011 X3 xDrive28i - Deep Sea Blue Metallic
2012 X5 M - Monte Carlo Blue Metallic
2017 X1 xDrive28i - Alpine White
      06-14-2022, 03:09 AM   #9
Nipsey
Thank you very much for the offer. Unfortunately I am up in Maine. No local shops have been able to reset it. The nearest dealer is over an hour drive. So I was hoping I could figure out how to load the software. If a foxwell or schwaben scanner would work I would just buy one. But I have thrown a bit more money at it than I planned buying scan tools that didn’t work.
      06-16-2022, 01:25 PM   #10
Nipsey
Just wanted to post an update. I have an autel mx808 and there was an update just released this month which added a ton of coding options and also made it bi-directional. There was also a very large update on BMW specific software.
So I just deleted transport mode. It could not have been easier. The user interface is excellent and it took all of 5 minutes. So anybody looking for a good scan tool that is bidirectional and fairly low priced. This may be an option. I did not explore any further but there was a huge amount of stuff under the service tag that was empty before.
wdb4732.00
