11-18-2013, 02:12 PM | #1 |
Ammar
73
Rep 406
Bluetooth Audio
This has to have been discussed somewhere else but my searching never seems to do me any good.
I have a DICE unit in my car when I bought it but the 30-pin connector is seriously messed up and I have an 8-pin. The thing I want is to be able to have bluetooth audio. I have a charge case on my iPhone and I don't think taking it out of the case just to listen to music is convenient. Especially since I have to get an adapter and fix the 30-pin connector. Has anyone done a mod to where the factory bluetooth can be configured to do bluetooth audio with music controls and album art? This would be amazing to have.
2018 F150 Platinum - Black/Black - Leveled on 34's - DD |
11-18-2013, 04:04 PM | #2 | |
Rep 1,107
11-18-2013, 04:14 PM | #3 |
Rep 273
The factory BT is for telephony only - it won't do A2DP Bluetooth audio. Some of the Dice units will, depending on what model you have. If you set up the Dice to pair with your phone for BT audio, you don't need to have the cable connected to stream music. The cable is only required to charge the iPhone or play wired digital audio.
11-18-2013, 09:27 PM | #4 |
Ammar
73
Rep 406
Hmmm... But I know for a fact that you can't be connected to two bluetooth devices at one time. So I couldn't use the factory bluetooth for calls AND a dice bluetooth unit for audio.
Another reason I asked is because I want the entire Nav/multimedia interface to be very uniform and not have so many extra crap and just be one solid unit that does everything. Kinda like what the newer BMW audio systems are like. They have the option of plugging in USB and having audio/calls, having wireless bluetooth audio/calls or both and just have the wire for charging.
11-18-2013, 10:20 PM | #5 |
salty cowboys fan
6158
Rep 3,407
When I use my iPhone via BT in the car, I can also hear the clicks from using the keypad or when I press the power button on top... if the sound effects can make it through, I'd bet there's a way to get music to go through also. Maybe someone more clever than I can figure out a way.
11-19-2013, 01:41 AM | #6 | |
HNIC
31
Rep 177
so hypothetically, i can be connected to my Jawbone Jambox speaker, my bluetooth headset, and the BMW factory bluetooth. if i'm playing music through my jambox and i get a call, the call will go through the jambox speaker by default since it's already playing music. however, through my phone, i have the ability to select which bluetooth audio device i want to pick up. I can use my phone to select the BMW bluetooth (for whatever reason) to play my phone conversation over the car speakers and microphone. if the call then turns into a private conversation, i can then switch over to my bluetooth headset. when the call is over, the music will resume on the Jambox Speaker even though i switched audio sources twice. At least with my iphone, it will remember the last settings. so if i get another call during my drive, it will default to the last settings that were used (jambox for music, and headset for a call). from my understanding, the bluetooth unit in our cars do not support A2DP (Advanced Audio Distribution Profile), which is what is required for 2-channel stereo streaming of music through a bluetooth connection. I have not heard of any factory/OEM retrofit that will allow us to use a bluetooth module from a newer bmw that supports A2DP, i believe (for now) our only option is to go through a mediabridge-type aftermarket solution. we can, however, upgrade the microphone for our bluetooth connections, which i'm currently trying to test. i just haven't been able to scrape together time to take the steering wheel column apart to swap the microphones. |
11-19-2013, 02:48 AM | #7 |
Ammar
73
Rep 406
Interesting. Very interesting. I'll see if it does this.
12-28-2013, 06:41 AM | #8 | |
Rep 2
12-28-2013, 07:15 AM | #9 | |
Rep 145
http://www.zpost.com/forums/showthread.php?t=784148 |
