12-04-2013, 02:21 AM | #1 |
Rep 7,408
Who uses aux jack for iPhone connection?
I tried it but there is too much static noise..... can't stand it
its monster jack 24k gold plated as advertised. I will probably return it. Or what if jack is not the problem?? anyone have similar experience? |
12-04-2013, 04:05 AM | #2 |
Rep 5,329
i use my everytime to drive the z4..... no static whatsoever and sounds like a CD , and im using a cheapo 7 bucks Aux cable.... i use this to stream music via 4g internet from a radio app.... works perfectly.
12-04-2013, 10:23 AM | #3 |
Rep 1,224
I use it and have no problem with my ipod. I had a similar problem to what you describe and discovered that my ipod volume setting was very low. Turning the volume up to max removed all the static/hiss.
12-04-2013, 10:34 AM | #4 |
Rep 1,001
No problem here! Using a cheapo $2 cable from Monoprice. Like other said, turn the phone volume all the way up might help
12-15-2013, 10:09 PM | #5 |
Rep 12,565
Mine eventually developed static and turned out to be the audio cable had gone bad due to the constant bending. Now I use a right angle plug and don't have any issues.
12-15-2013, 10:45 PM | #6 |
Rep 1,034
It works great in my Z4 but in my parents 2008 X3 (same radio) there's a bunch of background noise. But it goes away if I use a line out dock cable instead.
12-16-2013, 08:27 PM | #8 |
Rep 247
I get a little static at low volume, do get a hum while charging iPhone…otherwise its ok…rather hear my exhaust anyways..
| 2008 Interlagos Blue Z4MC | | AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust | |
