07-13-2012, 06:38 AM | #23 | |
Rep 4,531
My business is always going to them when possible. I'm sure you won't be disappointed! |
07-13-2012, 09:19 AM | #24 | |
Rep 12,565
07-13-2012, 04:21 PM | #25 |
Rep 222
Does anyone know if the H&R sway bars for the E46 M3 (front 30mm and rear 25mm) will fit the Z4M? The Z4M shares the same OEM rear sway bar with the E46 M3, so the H&R rear bar should fit, but the Z4M has a slightly bigger front sway bar than the E46 M3, so I need to find this out.
I live in the UK, so importing the GC sway bars will cost me nearly twice the price that I'd have to pay for the H&R kit for the E46 M3, if it will fit. |
07-13-2012, 05:32 PM | #26 | |
Rep 4,531
I run a front bar with no problems. It costed me $270 + tax (picked it up locally) http://www.tcklineracing.com/webdocs.../Details96.cfm TCK helped me figure out it was a guarantee fit. Rear bars do not help much on our cars. Don't waste your money. Erik at TCK said he'd love to sell me a rear bar, but he said no gains would be there...and advised me to stick with a front bar. They are awesome. Turn away money for a good set-up? I rarely see that. |
07-14-2012, 04:16 AM | #27 | |
Rep 5,329
07-14-2012, 04:49 AM | #28 | |
Rep 222
07-14-2012, 06:26 AM | #30 |
Rep 5,329
C A automotive.....give them a call and ask for ROY..he supplied this to 3 uk guys now.
07-14-2012, 09:40 AM | #32 |
Rep 222
Not necessarily true. It is a piece of metal with the qualities of a spring. But I agree that all else being equal, I would rather pay less than more for the same thing.
07-14-2012, 10:26 AM | #33 |
Rep 4,531
I'd love for someone to show me that they can tell the difference between 30mm sway bar (A) and 30mm sway bar (B)
07-14-2012, 11:30 AM | #34 | |
Rep 222
8" = 100% 7.5" = 113.9% 7" = 130.7% 6.5" = 151.6% 6" = 177.8% Since the H&R 30mm sway bar has 3 different drop-link positions, it looks to me that there will be at least 30% increase in stiffness from the lowest to highest settings on that bar if the holes are set at 1/2" apart. I'd like to think that you could tell the difference between any of those three setting positions at the least. |
07-14-2012, 02:37 PM | #35 |
Rep 1,269
I've run the GC S/A coilovers on my M for about 10k miles. Aside from the initial mix-ups where GC shipped the wrong parts 2~3 times, the coilovers have worked fine and as advertised. No noise (certainly a lot quieter than the TCK kits I had). But I do think there's something special about the TCK D/A's; they really made the car feel a lot different; handling just felt smoother and comfort was noticibly better and the car felt lighter and more responsive. I just find myself keep going back to the TCK's. TCK is currently custom-building (in-house) new D/A struts for me that they gurantee will be completely noise-free. This is of course more costly and I'll see if they justify the costs.
2019 Porsche 911 4 GTS
2016 BMW M3 2008 BMW Z4M coupe |
07-14-2012, 03:49 PM | #36 | |
Rep 4,531
Metal Bar A that is $400 and is 30mm Metal Bar B that is $270 and is 30mm You won't tell the difference. |
07-15-2012, 01:12 AM | #37 |
enthusiast
48
Rep 1,695
If they are the same. The GC bar is designed very differently and has infinite adjustments compared to HandR. It is also a hollow bar, and is probably 20lbs light than the Hand R bar.
The links are also different also. |
07-15-2012, 05:33 AM | #38 |
Rep 222
I did understand your comment. My reply was that although 2 pieces of 30mm diameter bar might have the same outward appearance, their spring qualities may well be different, and I merely used the scale as an example of the difference in spring effect from relatively small differences.
07-15-2012, 07:06 AM | #39 | |
Rep 222
They have been very responsive to the issue though...
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters |
07-15-2012, 09:28 AM | #40 | |
Rep 12,565
Please post pics after your GC kit is installed, and before & after measurements from center of wheel to fender will be very helpful =) |
07-15-2012, 12:47 PM | #41 | |
Rep 1,739
Drives: 2008 Z4MC
07-15-2012, 01:03 PM | #42 |
M = Midlife Crisis
65
Rep 2,006
My Single Adjustable Koni front and rear GC's with 500/600lb springs work just fine. Customer service when I purchased 19 months ago from Jay was outstanding! He called me and took the time to walk me through all the various setups and land on what would best suit my needs.
2006 Z4MC - #LL93158
07-15-2012, 01:52 PM | #43 | |
Rep 222
2007 3.0si Coupe
07-15-2012, 03:18 PM | #44 |
Rep 1,269
If you're just doing the camber plates, go with Vorshlag. Much better than the GC plates in terms of ease of adjustments, quietness and maintenance.
