      08-22-2022, 01:18 PM   #89
ctdriver86
Drives: e46 m3
Hello Randy, thanks for the help. I also have an e46 m3 and had some parts laying around so I used ACL WPC treated rod bearings with OEM rod bolts. The bearings I pulled from the 94k mile z4m were definitely due. Copper was showing on all top bearings. I'm guessing maybe it has to do with how often the car was driven?
I pulled bearings from my m3 at 155k miles (no history) and the bearings were in much better condition. The car was neglected so I doubt the bearings were done. I also pulled bearings from a 72k mile 2002 early rod bolt m3. The car was driven often until around 72k miles and was in a rear end collision where it sat for over 10 years. The bearings were in good shape actually. It's just my speculation since I don't seem to see a consistent pattern of wear with the s54 bearings other than the top bearing wear maybe on ignition stroke?
      09-14-2022, 10:12 AM   #90
Emmrbee
Retired
Emmrbee's Avatar
Drives: 2006 Z4M Roadster
Replaced with VAC high performance rod bearings and ARP M10bolts
Engine mounts changed at the same time. Engine had 76,411 kilometres on the clock.
      10-03-2022, 03:43 PM   #91
grannyknot
grannyknot's Avatar
952
Drives: 2008 Z4M coupe
Just got to the rod bearings and main bearings, pretty sure the rod bearings are the second set, the mains I think are original, car has 91,000 mi.
Would like to hear anyones read on the mains, the journals on the crank are very nice.
First pic is the uppers, can anyone tell me what those blobs are on the lower 6,5,4 bearings?
Last pic are the mains.
2008 E86 M coupe
      10-03-2022, 10:38 PM   #92
maupineda
Drives: E86 Z4MC
Do you know the mileage on the second set? They were not due for a change and IMO could have gone for another 30-40k kms.
Mains are barley worn, but without measuring them, is tough to say how much. They did not need changing though. These engines do not consume main bearings as is the caee with the rods’.
      10-04-2022, 01:09 AM   #93
ctdriver86
Drives: e46 m3
You changed the main bearings without removing the crank?
      10-04-2022, 05:13 AM   #94
grannyknot
grannyknot's Avatar
952
I don't know the mileage when they were changed, was given very little history of the car. It is the weird spots on the mains that have me puzzled.
No, I just opened the engine and this is what I found but I will be replacing all with fresh bearings.
2008 E86 M coupe
      10-05-2022, 02:07 PM   #95
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
Speaking of rod bearings just bought an RSX for soon to be driving child.
174k miles = No worries:
- K20 engine
- full maintenance records - oil changes from day one, average every 3k miles
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
