      11-17-2016, 06:15 PM   #1
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
H&R Coilover Broken Rear Adjuster
Last week, one of the rear height adjusters on my h&r coilover setup snapped while I was on the freeway. I think it had been slowly deforming over the prior week as I noticed my car was lower than normal, and I was waiting for the weekend to check it out... never made it to the weekend it caused the wheel to get extra cozy with the fender liner, and ate her right up
Was able to order a new adjuster (and tires...) and installed it, but I'm not convinced that the h&r design is any good. The adjuster isn't really aligned to the angle of the spring. I ordered a set of ground control articulating rear adjusters for the e46. FYI if you order directly from their site, you can choose between 2.25" or 2.5" cones, which isn't an option I found at other distributors
Of course, when I got the new tire mounted the guy fucked up my wheel. Every goddamn time, I swear. Hate letting other people work on my baby
XMetal1136.00
      11-18-2016, 10:28 AM   #2
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Wow Glad you're OK - I could just imagine how dangerous that could be. I have to remember this potential issue if I ever decides to upgrade suspension in the future. Thanks for the head's up.
Of course, I feel your pain on the wheels I need to find a good tire installer myself. The America's Tires I usually bring it to is a hit or miss.
yousefnjr6159.00
      11-18-2016, 11:49 AM   #3
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
Its indeed a strange adjuster.
Looks like a metal fatigue issue. What is that inner thread size that snapped?
M14x1,25 or M16x1,5?
Most coilovers use a different design (same as kw/GC etc), so this kind of style:
Where yours is similar to this I think?
I think this type of adjuster only fits on the bottom, so on the control arm. that constantly changes angle, so forces are constantly wobbling from one side to the other. If it would sit on the top, those shifting forces are more equalled out in the spring I think.
yousefnjr6159.00
      11-18-2016, 02:35 PM   #4
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
^^ yep that's the one, you're right. A quick googling showed me that it's not uncommon for these to fail, should've sprang for the KW's
      11-18-2016, 03:25 PM   #5
Drives: M2 Comp
These are also known to damage the control arm
yousefnjr6159.00
      11-19-2016, 12:09 PM   #6
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
I thought it was a strange weak design when I installed mine, you can always buy adjusters for KW or BC Racing or similir who have the same type of design.
yousefnjr6159.00
      11-19-2016, 12:46 PM   #7
GuidoK
#buildnotbought
GuidoK's Avatar
10859
But the question is, will they fit?
For the bottom half of the h&r spring the OP can fit for himself as the h&r spring has to fit into the stock bmw rubber spring pad (my guess is that the H&R spring will have a larger lower diameter than that the spring pad has).
For the top half of the H&R spring it has to fit that KW adjuster. I dont know if the diameter of that adjuster is the same as that stock spring pad the h&r spring sits in.
Of course he can buy a fitting kw or bc spring, but theres a chance that that doesnt match well with the front setup if thats much stiffer or much softer than the kw/bc setup
Actually the H&R springs look a bit like kw springs but fitted upside down. (where kw has the softer coils on the bottom and the stiffer coils on top and with H&R its the other way around)
yousefnjr6159.00
      11-20-2016, 03:15 AM   #8
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
My experience is that most adjusters have a diameter of 60 mm (fits race springs). To be sure he would have to measure of course. So in theory he could always buy race springs and choose the same load rating as the H&R kit.
      11-23-2016, 12:01 AM   #9
Mike_Z4M
Drives: Z4MC
Hey bud quick question, where did you buy a replacement adjuster from? Also, you mentioned you bought one from GC, do you have the link to it? I just installed my H&R'sport today, want to be ahead of future issues. Thanks!
      11-23-2016, 10:12 AM   #10
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Ordered the replacement H&R adjuster here, looks like they're on back order for a couple weeks FYI
Ordered a pair of GC adjusters here. Should be coming in the mail today, and I'll be installing them in a couple weeks when I do my brakes, will post an update then
      11-23-2016, 12:10 PM   #11
Mike_Z4M
Drives: Z4MC
Thanks you sir!
      12-08-2016, 09:21 PM   #12
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
So finally found some time today to swap the h&r adjusters out for the ground control ones. Turns out my other side was broken too. Frankly, I'm more surprised that the replacement adjuster I installed a couple weeks ago was still in good shape.
Junk. Anybody with this kit should take a look at theirs, especially if riding on 19s
      12-08-2016, 09:48 PM   #13
Drives: M2 Comp
here's the other issue that can be caused by these type of adjusters.
Too much load is placed in the middle.
yousefnjr6159.00
      12-08-2016, 11:02 PM   #14
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
Yikes, praising the lord they only took a tire with them on mine. Ouch.
      12-09-2016, 08:30 AM   #15
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
This is worrying...
Just saw the GC link you provided. Which size fits the H&R spring, 2.25" or 2.50"?
Since the GC ones are articulating heads vs the original H&R which are fixed, will it change the handling characteristics in any way?
      12-09-2016, 09:16 AM   #16
Drives: M2 Comp
Originally Posted by pcube View Post
This is worrying...
No it wont.
The articulating head just keeps the spring inline better.
R.Eng also has the same type of mount, with a write up on function.
pcube57.50
      12-09-2016, 10:57 AM   #17
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
This is worrying...
I ordered the 2.5", but they didn't quite fit. What they give you is a pair of 2.5" plastic spring pad "adapters", but they didn't quite fit the bottom of the h&r spring. The very end of the coil wasn't clearing the adapter. Without the adapters, the spring wasn't getting enough purchase for me to be comfortable either. I ended up cutting out a small portion of the adapter pad plastic to allow the spring to fit.
I also ordered the nylon cones for the top. They gave me 2.5" and they don't fit at all. There isn't a selectable option, but maybe contact them and see if you can get the 2.25" upper cone if you need them. I ended up just reusing the factory rubber padding.
pcube57.50
      12-10-2016, 06:18 PM   #18
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
The H&R failures are frightful.
Racerbruce
      12-31-2016, 06:11 PM   #19
2286
Which is why I have these...
http://www.bimmerworld.com/Suspensio...rE4aAu6o8P8HAQ
      01-01-2017, 05:21 PM   #20
yousefnjr
salty cowboys fan
yousefnjr's Avatar
6159
^^ yeah definitely the way to go. The GC adjusters have a plate just like that as well, good peace of mind after seeing that pic!
Side note, had to raise my rears yesterday, and was impressed that the GC adjusters can do this without jacking the car up (although it's much easier to crank them if you take a little load off by jacking a couple pumps). H&R's had to be completely unloaded.
