Go Back   ZPOST > Marketplace > Sponsors Classifieds
      11-01-2012, 03:39 PM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
818
Drives: Independent Tuning Specialists
:: ECS Tuning :: The only gauge that doesn't clash with your interior|OE Styling
Need a complete boost gauge kit for a custom application? ECS proudly announces our new universal Boost Gauge Kits. Each kit contains a 42mm illuminated boost gauge, plus pressure transducer, wiring, and hoses.
Just tap into a manifold vacuum source at the engine using the enclosed vacuum tee. Then run a vacuum sampling line into the cabin and connect it to the transducer. Plug in the transducer, and connect the gauge to power with the wiring harness and bullet connectors in the kit.
This versatile package makes it easy to install this bright, accurate gauge, in any car.
Click HERE to order your ECS BMW 45mm Boost Gauge Today!!!!!!!!!
Not for use in Valvetronic Motors
      11-06-2012, 10:03 AM   #2
ECSTuning
ECSTuning's Avatar
818
      11-20-2012, 02:39 PM   #3
ECSTuning
ECSTuning's Avatar
818
There is no better time to buy than NOW!!!!!!!!!!!!!!!!!!!!!!!!
The best boost gauge for your BMW from ECS Tuning is now 15% OFF as part of our 8th Annual Holiday Extravaganza!!!!!!!!
