08-04-2010, 05:58 PM | #23 | |
Rep 2,138
Drives: Me
As I have stated in other posts, when I set the cruise at 65, I get 26-27MPG. Of COURSE your MPG will go down when the RPM's go up. I find that anything over 3K RPM then your MPG starts to really suffer. When we went to HC08 in my wife's Roadster, trunk PACKED... and driving 75 MPH, I would get 31MPG... That was a memorable trip.... It was the first time I saw a MC in the flesh (Caddyshk's) and fell in love... On the circuit to/from work, about 12 miles of city and 13 miles of highway, depending on how I drive, I get anywhere from 16 to 22 MPG. It all depends on my foot. I find that I drive very easy in the morning but start to hoon it up on the way home from work.... I also have made some posts about the accuracy of the trip computer. Mine seems to be very accurate. But I always do the Miles/Gallon computation.... As inTgr8r has stated and I whole heartily agree, these engines get amazing fuel mileage.. As I am driving home tomorrow, I can't wait to get into my ///M on Friday for the drive to work. To be in a real car again..... |
08-04-2010, 07:02 PM | #24 |
Viper Driver
36
Rep 1,311
after purchasing my car in houston, i made the six hour journey west to del rio, almost 95% highway, averaged 80mph and 24.2mpg. from watching the consumption meter, i'm guessing the optimal speed for the m's (perhaps for most cars for that matter) to be between 70 to 75mph.
08-04-2010, 07:48 PM | #26 |
Rep 165
I see consistently 20 -21.5 mpg in my ///Mr. If I happen to take a trip with about half the tank run on the interstate - and I will do 75 minimum on the interstate - I will see my mileage hit 24-25. I would expect that if I did an entire tank on the interstate I could get it up to 28 or better.
In the FWIW dept... my winter car is a 2007 Ford Expedition Eddie Bauer. In the summer time I get 15-16 mpg. This is driving the same roads, traffic etc that I now use my ///Mr for during the summer, so my ///Mr is an improvement. A couple years ago, I took the Expedition out to Ohio to pick up my daughter from college. On the way home, I filled it up in literally a mile from the interstate. I then went over 400 miles before getting off the interstate in Troy NY. My gas guage said I still had close to a quarter tank (I normally would get just under 400 miles on a whole tank). Well, I didn't believe the guage - it had to be wrong, so I filled up. I checked the numbers and I had got 20.5 mpg in my fully loaded SUV. Again, this was literally the entire trip on the highway with the cruise set at 74. BUT, I can see how our ///Ms could potentially get in the high 20s doing a whole trip on the highway, even at the speeds *cough* some of us drive |
08-04-2010, 08:30 PM | #27 |
Enrollment Officer
114
Rep 5,014
08-05-2010, 07:23 AM | #28 | |
Rep 1,546
either way, it's good to me to get over 300 with this engine and only 14.5gallons.
08-05-2010, 08:23 AM | #29 |
Rep 1,855
Are the speeds you guys are quoting ACTUAL (gps verified) or the displayed speed on the speedometer? I think there's like a 3-4 percent difference in my car (speedometer shows faster than actually going).
08-05-2010, 08:29 AM | #30 |
Rep 1,546
mine are from the speedo...
08-05-2010, 09:02 AM | #31 | |
Rep 615
08-05-2010, 12:44 PM | #32 |
Rep 725
08-05-2010, 01:02 PM | #33 | |
Rep 1,546
but yeah, normal day to day i just fill up at 1/4 tank/wne the light comes on.
08-05-2010, 02:57 PM | #34 |
Rep 1,143
WTF. Is there something intrinsically wrong with my car that's limiting my fuel economy? At the end of the day, I don't drive enough to really care whether I get 16 MPG or 26 MPG, but I'd like to know if there's something wrong with my engine.
Granted, I've only taken one extended trip on the highway, averaging probably around 80 in 6th gear. Combined with a bit of local driving before I needed to fill up, ended up just over 18 MPG. This is (odo after filling - odo after previous fill)/gas added until pump stopped. Locally, I've seen as low as 13 MPG with no highway driving to around 17-18 mixed. My tires are properly inflated. Car is completely stock aside from OE strut brace and aero side skirts. I rarely take it above 6K RPM, usually shifting around 3.5 or 4K. Sport mode never engaged. Ambient temperature in the 80s. Gas is always Shell V-Power 93 octane. Last oil change done maybe 2 months. I weigh ~170 lbs. with clothes and there is rarely ever anything else in the car except for a laptop bag and carpet floormats. Windows up above 50 MPH, AC on if necessary. Only thing I can think of is that the dealer might have overfilled my oil. I have to double check on my next drive, but there's probably an extra half quart in there that I fashioned a syringe to extract. During the PPI, they found that my oil was overfilled from the previous owner too. Is there anything else I should check? |
08-05-2010, 04:24 PM | #35 | |
Rep 2,138
Drives: Me
Two years ago, my Roadster was suffering from MPG issues compared to most others I found on the boards. The engine threw no codes and there where no drivability issues other than a 5-9 MPG loss. With out a code it took some detective work.. Long story short, both of my upstream O2 sensors were weak but NOT throwing a code. The sensors were always showing the DME a lean condition, which means they were dumping fuel into the cylinders. Using my AutoEnginutiy Laptop scanner I was able to figure this out... I replaced the sensors and the problem was fixed. The dealer probably won't touch that issue without a code.... Not saying this is your issue because MPG issues could be so many different things and have a lot if variables... |
08-05-2010, 05:18 PM | #36 | |
Rep 615
08-05-2010, 07:51 PM | #37 |
Rep 413
Drives: Z4 3.0, CLS63 AMG
While I don't have an M, I do have a CLS63 AMG that gets about 15 mpg city/highway, Z4 about 28 mpg city/highway and about 40 mpg on my Yamaha R1. In other words, I figure that balances everything out. I'm getting just over 20 mpg average on the vehicles I drive...lol
2005 BMW Z4 Roadster 3.0 - Black Sapphire with Red Extended Leather / NAV / Premium & Sport Pkgs / 19" wheels / M steering wheel / Xenon
2013 Mercedes CLS63 AMG |
08-05-2010, 07:58 PM | #38 |
Rep 2,138
Drives: Me
Before MPG was 23-25. After 30-32.
Remember, this was on the non-M Roadster.. I was able to monitor the O2 sensors in real time and discovered that the voltage range they were running at was 0 to .4V. They should be .2 to .9V with .45v as the center point for the cross count. |
08-05-2010, 10:44 PM | #39 | |
Car Geek
3717
Rep 3,625
I would say that to get the BMW specified consumption, you have to drive with a light throttle and keep the revs between 2000 and 3000RPM. In Canada the highway consumption rating is 9.0l/100km (26.1 US mpg), the best I have ever managed is 8.9l/100km (26.4 US mpg) at a steady 110km/h (68mph), when measured by litres used at the pump. The urban rating is 14.5l/100km (16 US mpg), the normal I achieve is about 13.5l/100km (17.4 US mpg), the worst about 17l/100km (13.8 US mpg) when driving fairly aggressively. |
08-05-2010, 11:02 PM | #40 |
Viper Driver
36
Rep 1,311
aerobod, ur figures sound about right. i just took a trip out to lake pecos to catch the sunset, and did a bit of mpg readings on the bc myself. seems like the car could do with a 7th gear for further improved fuel economy, especially at speeds in excess of 70mph. i'd revise the most fuel efficient cruising speed to be about 65mph, giving me on average about 28mpg. am on 93 octane so that may have a slight impact.
08-06-2010, 12:15 AM | #41 | |
Car Geek
3717
Rep 3,625
08-06-2010, 03:34 PM | #42 |
M = Midlife Crisis
66
Rep 2,006
The best tank I've averaged was 8.4L per 100km - worst 28L per 100km
2006 Z4MC - #LL93158
