04-14-2015, 07:57 PM | #1 |
Rep 788
Z4C Track Build Thread
I posted some tidbits here and there about my plans for the car, but wanted to start an official build thread.
A little about me: I've been racing sportbikes for the last 8 years and instructing the last 3, but just got into track driving in a car last year. I know this Z4c isn't the most typical "track" car, but I love the looks and how engaging it is to drive. It is way more fun and nimble than the 135i that I sold last summer. I've owned a number of sporty cars, but never had a car where the majority of the driving will be track based. Vehicle -2007 Z4 Coupe -One previous owner -85k on the clock when I bought it Phase 1 mods, completed 4/14/15 -Breyton GTS-R wheels -12mm spacers up front, 10mm rear -Koni double adjustable/H&R springs -Wheel spacers for the Breyton wheels -4 new OEM wheel roundels (3hp each) -SS brake lines/RBF600 fluid -FrozenRotors slotted front brake discs -Hawk front pads -New OEM floor mats (10hp each) Phase 2 mods, purchased and waiting to install -M steering wheel -aFe air filter -ZHP shift knob -3.91 LSD from Jim at Performance Gearing Phase 3 mods, under consideration -Full coilovers -8.5" front wheel -??? Original With just the wheels Phase 1, 4/14/15 |
04-15-2015, 10:22 AM | #3 |
Rep 28
i don't want to pee in your cornflakes, but get an oil analysis done and check your rod bearings. although my oil analysis was fine, the rod bearings were into the copper at 47k miles. they really are a sacrificial part.....and much cheaper than crank work/replacement
04-15-2015, 10:25 AM | #4 | |
Rep 10,602
04-15-2015, 01:55 PM | #6 |
Rep 904
I think he saw "Z4C" and "track" and automatically thought M.
BGR: Looks good, but by the time you're done with Phase 3 or 4, you could've just bought a Z4M for the same price. Obviously as an enthusiast you're probably doing it for the fun of modding, not to turn the 3.0si into something that can outperform a stock Z4M on the track. What's the 8.5" front wheel in Phase 3? You just put on new wheels... |
04-15-2015, 05:31 PM | #7 | |
Rep 788
Right now I'm at $20k total including car, parts, and install costs. After phase 2 gets installed, this car will be more capable on the track than a stock Z4M, with lower insurance and upkeep costs. And like you said, this is more of a unique, enthusiast project. I've never gone "all out" building a track car so it is fun for me. Also, for what it's worth, the dealer I bought the car from includes a lifetime powertrain warranty with used cars under 100k miles. I think my rear flex disc and/or center support bearing/driveshaft is on its way out so we will see how easy they are to work with when it comes to |
04-17-2015, 10:26 AM | #8 |
Rep 788
Completed the muffler delete last night. Sounds pretty darn good; almost zero drone and looks OEM from the back.
Compared to the Berk Race Exhaust (basically a muffler delete) on my 135i, this is a touch louder and more raw, likely because there are no turbos muting it. If I had to describe the sound, I would liken it to half of a Ferrari 250 GTO. Here are some pics, and I will try to get a sound clip tonight. |
04-17-2015, 10:58 AM | #9 |
Rep 222
While you're crawling around under the car, take a look at the front control arm bushings and the rear trailing arm bushings. Depending on the mileage, those may be in need of some attention.
I really like the Tree House Racing front control arm brackets and bushing on my car, but it looks like those are NLA, and Bimmerworld now actually has a slightly cheaper alternative-- http://store.bimmerworld.com/bimmerw...nts-p1301.aspx They also have a bearing set to replace the rear trailing arm bushings. I don't have any first hand experience with these though. http://store.bimmerworld.com/bimmerw...kit-p2138.aspx Before I refreshed the RTABs and put in companion limiters, I got a kind of "wiggle" out of the rear end between when the chassis finished rolling and the rear end took a set. Went away when addressed. Other track related suspension wear issues I've had over the 90,000 total miles I've put on the car are a rupture in the driver's side strut bearing and the inner ball joint on the same side front control arm-- seems to be more right turns than lefts at the track. Strut bearing issue addressed by installing adjustable camber plates-- not much to do about the ball joint except replacement.
2007 3.0si Coupe
Dinan Stage I Suspension (Shocks, Struts, Springs), Ground Control Front Camber Plates, Treehouse Racing Front Control Arm Bushings, RTAB Bushing Limiters |
04-17-2015, 01:20 PM | #11 |
Rep 788
04-17-2015, 01:20 PM | #12 | |
Rep 788
04-17-2015, 02:59 PM | #13 |
Rep 222
No info on the diff mounts, but if it's coming out, and there's significant mileage on the car, I doubt there's much point in leaving the old ones in.
If you're dropping all that stuff out, it's also a pretty good time to refresh the stabilizer bar end links and bushings too. Access to change out the end links is much easier with the axles and exhaust system out of the way. That stuff doesn't need to come out to do it though. When you got the diff redone, did you manage a mod or exchange to get a unit with a drain plug? Mine just has the fill hole, so I have to suction out everything I can.
2007 3.0si Coupe
04-17-2015, 05:55 PM | #14 |
Rep 788
Mediocre video/sound clip of the exhaust. Sounds a lot more raspy in the clip than in person.
(Disregard the safety wire. It is temporary until I get the hanger welded on tomorrow) Last edited by BGR; 04-18-2015 at 11:54 AM.. |
04-22-2015, 09:07 AM | #15 |
Rep 788
I ordered up a previous gen iPad Mini along with a SkyPro XGPS160 to use as my lap timer, and an iKKEGOL OBD2 WiFi device for systems monitoring.
I'm trying to decide where to have a custom mount made for the iPad. Since the car doesn't have nav, I'm tempted to cut into the dash and mount it where the OEM nav usually goes. Any suggestions? |
04-22-2015, 09:52 AM | #16 |
Rep 1,224
If you ever find yourself with a little extra time, it would be interesting to see what the Si muffler looks like inside. Over time there has been postings on the internals for the Z4M and pre-facelift Z4 boxes, but not the facelift cars.
Any plans for weight reduction, larger sway bars....? While everything is down you might want to consider reinforcing the front sway bar mounting area, see http://www.zpost.com/forums/showthread.php?t=870503
04-22-2015, 09:19 PM | #17 |
Rep 12,559
Garage List F15 X5 xDrive35i [8.33]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.33] E82 135is (Retired) [9.46] E85 Z4 M (Retired) [9.33] E90 328i xDrive (Re ... [9.00] E86 Z4 3.0si (Retired) [9.18] |
Very nice, I'll be following this thread. I just sold my 135is for an X3 but I honestly believe the Z4 is a more capable track car. The E82 would have the edge only on straights and coming out of turns but braking and overall handling goes to the Z4. You should add track pads to your list, and maybe even add braking cooling (I did a write up for Aero bumper).
PS: buy my coil overs and camber places, perfect for your 3.0si lol Last edited by 3002 tii; 04-22-2015 at 09:25 PM.. |
04-23-2015, 08:11 AM | #18 |
1593
Rep 4,293
nice car buddy, love the wheels on it, suits the car. Will be watching attentively at which mods your going with next
Powered by |
