02-24-2014, 10:03 PM | #1 |
Rep 588
Drives: 2007 Z4M Coupe
Antenna help
So I was trying to install a stubby antenna and things didn't go so well. Took the stock antenna off with a set of pliers.
I noticed the bolt for the stock antenna was messed up(I don't know the proper terminology) after removing the antenna. The stubby antenna came with inserts. I'm just wondering how to remove the stock insert so that I can install the insert that came with the stubby. Hopefully I'm not rambling and someone knows what I'm talking about. Thanks.
2021 m240i on order
02-27-2014, 07:14 PM | #2 |
Rep 2,546
Did the male threaded part not come off with the antenna? If so, you could thread 2 nuts onto it and tighten them against each other. That should allow you to loosen it and remove it.
02-27-2014, 09:11 PM | #3 | |
Rep 588
2021 m240i on order
03-02-2014, 07:04 PM | #4 |
Rep 441
Same thing happened to me...I had to replace the base which turned to be a bit of a pain in the ass haha
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
03-03-2014, 08:21 PM | #5 | |
Rep 588
2021 m240i on order
03-16-2014, 06:31 AM | #8 | |
Why so serious?
141
Rep 743
Canadian buyers should speak to them before ordering. They can figure out an alternate way to avoid custom fees |
