12-05-2017, 01:20 PM | #1 |
Rep 1,351
Drives: in Anger.
Codes thrown - Help!
Hello everyone.
So clearly my car is mad at me for selling it...it has thrown a couple codes while on the road to the new owner, driven by the new owner. Any idea ? I am lead to believe an O2 sensor. P2098 P2272 any help is greatly appreciated, i did do a brief search to no avail.
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs 1217/1815 !!! BOILER UP !!! |
12-05-2017, 01:44 PM | #2 | |
Rep 870
Drives: 2006 BMW Z4M Roadster
Salty
12-05-2017, 02:01 PM | #3 |
Rep 1,351
Drives: in Anger.
No haven't touched the AFE.
12-05-2017, 02:16 PM | #4 |
Rep 240
12-05-2017, 08:09 PM | #5 | |
Rep 1,351
Drives: in Anger.
So how do I know which sensor it is? Or is it both?
12-06-2017, 05:32 AM | #7 | |
Rep 2,782
While the O2 sensor is most likely culprit, many things can cause these codes, including: - Pre-cat O2 sensor (controlling the fuel trims) - MAF sensor - Catalytic converter I'd go with a Bosch O2 sensor (much cheaper than OEM).
12-06-2017, 05:50 PM | #8 |
Rep 1,351
Drives: in Anger.
So it sounds like its likely the downstream bank 2 O2 sensor. Its showing a lean fault, and that means either the wiring is faulty, there is an exhaust leak before that sensor (but after the pre-catalyst sensor) or the sensor itself is bad. the strong likelihood of all of those is the sensor itself is bad. - Trusted tech friend
12-06-2017, 05:51 PM | #9 |
Rep 1,351
Drives: in Anger.
Thanks!
12-06-2017, 05:54 PM | #10 | |
Rep 1,351
Drives: in Anger.
12-07-2017, 12:38 PM | #11 |
636
Rep 3,124
I was getting similar codes long ago and found some wires pinched under the valve-cover-cover.
Right where the wires enter at the right rear and then split out under the cover to cylindrical connectors a couple run against the side of the boss with the stud. They got up on top of the boss and were crushed. Only threw codes when it was good and hot and the insulation softened.
