04-20-2022, 12:15 PM | #1 |
Rep 229
Z4m s54 vanos
No codes set , but a slight engine hesitation from idle. I had an inclination to pull the connector from the solenoid coil pack and splash some Stabilant 22A on the terminals just to ensure that the little guys were still speaking to each other. About two hours later it became evident that the connector wasn't ready to yield to my efforts. I was ready to cut the cable tie that retained the cable to the connector, but I'm not convinced that the cable tie was causing the problem.
So, removing the solenoid coil pack and valve body, to get easier access to the connector, became very tempting. Not too expensive with the Beisan refurbed coil pack. Finally, the question: With the valve body unbolted, can the valve body and coil pack be removed toward the intake side of the engine WITH THE ELECTRICAL CONNECTOR STILL ATTACHED? Any guidance is appreciated!! Thanks. Ted |
04-20-2022, 01:21 PM | #2 |
Rep 264
I wouldn't do that. BMW electrical connectors are very brittle and pulling it through tight spots can break some. Plus I don't think wires are long enough.
