04-13-2022, 12:39 AM | #1 |
Rep 2,877
Coupe Headliner Fabric Delamination
Anyone have issue with their headliner fabric becoming unglued on their coupe? Just started noticing some fabric separation from the headliner on the corner of the sunvisor areas on both driver and passenger sides. My coupe is mostly garaged in a dry So Cal climate and I thought this would help slow the delamination process down, but I guessed this may be one of those environmental friendly glue that BMW is using that isn't holding up too well?
04-13-2022, 06:38 AM | #2 |
Rep 305
Had that happen to my '06 last fall. It started in a few spots but progressed rapidly over just a few weeks until over 1/2 of the material had separated. Pulled the ceiling panel out, stripped out the remaining fabric and the backing and replaced it all with microsuede (generic alcantara) headliner material.
That was a PITA to glue the new material back into place without getting nasty wrinkles in it. BTW - I don't think it's the glue which is the problem. There's a thin foam layer between the fabric and the panel which, over time, deteriorates and turns to dust. I don't know if it's due just to age or if it's a heat cycle issue. Mine was mostly parked outside which I'm sure contributed to the headliner failure.
2006 Z4 coupe - with HOMELINK!
1966 Mustang GT fastback (too many mods to list) 2015 335i GT 2014 981 Cayman S manual |
04-14-2022, 07:54 AM | #5 |
Rep 430
Normal on old cars. Bought a hard top from a guy who had it hanging in his garage close to the ceiling for like 12 years since it was new. The headliner was in absolutely terrible condition and was basically a dirty rag hanging.
Used that same suede type headliner material (its pretty cheap on ebay) as mentioned above, some 3M headliner glue (glue is very important), a couple of hours watching youtube to get the process down and make sure I don't f... up and its beautiful now. Still ended up with a couple wrinkles but its not in a very visible place so it doesn't matter. Its not as easy as it first seems though. Don't be fooled because a pro on youtube does it and makes it look like piece of cake. Prepare properly. Pro's charge quite a bit for this job and its mostly labour. I spent about a $100 on materials vs a couple shops that quoted me $600-$700 CAD to do this. |
XMetal1148.00 |
04-14-2022, 05:14 PM | #6 |
Rep 86
Drives: 3.0si Coupe
I attempted it myself with the headliner adhesive spray. It turned out to be harder than it appeared and I had to tear off my attempt. It wasn't worth the time to fail a couple more times to master it...
XMetal1148.00 |
04-16-2022, 09:29 AM | #7 |
Rep 72
Happened to mine as well. Mine has always been garaged and my garage is shaded by trees so it never gets real hot in there. I definitly think it is just an age, heat and possibly humidity issue.
04-16-2022, 09:32 AM | #8 |
Rep 72
I plan on having mine done in alcantara or the micro suede. Was also thinking about having the pillar covers done as well since they are the same headliner material. Has anyone else done this?
I want to keep mine as stock as possible but I have no choice with the headliner and I love the alcantara look so I figured why not. I didn't intend for my car to be a garage queen but it happened naturally due to life, kids, etc. |
04-16-2022, 09:49 AM | #9 | ||
Rep 2,877
04-18-2022, 09:03 AM | #10 |
Rep 305
Yep - that's what I did. The A- and B-pillar covers are pretty simple compared to the ceiling panel and since everything is apart anyway, there's no real reason not to.
