04-21-2011, 12:05 PM | #1 |
Rep 525
Z4 Remote Top Down - Must Key Be Programmed?
Hello All -
I can't seem to get the keyfob activated remote top down function to work in my 2008 roadster. I press unlock once to unlock driver door, press unlock again to unlock passenger door, then press and hold unlock again to retract the soft top -- and nothing happens. I searched the forum pretty diligently but can't determine if this function must be programmed by the dealer to work, or if it should just work on ALL later model year cars. I've looked at the list of programmable options, but see nothing that seems to relate to this function. Any thoughts? Many thanks.
04-21-2011, 01:36 PM | #4 |
Rep 86
I just contiuously hold unlock button. At a minimum of 5 seconds the windows go down halfway, then the top begins retracting. Continue to hold till complete and the motor stops. Range of remote is crap, but that's another issue.
04-21-2011, 02:03 PM | #6 |
Rep 525
I doubt I'm too far from the car, i.e I think I was standing about 10-15 feet away (will try again this evening). How close are you guys needing to be for it to work? I do know that the locks were unlocking fine. Is the "top-down" range less than the locks?
04-21-2011, 02:16 PM | #7 |
Rep 86
Hit n miss if over 10 ft from car. Only way to be sure u don't look like a D ass is to b next to car. Top up doesn't work with remote(without modification). You can Put key in lock turn right n hold: will lock doors, then put top up, then windows up.
04-21-2011, 03:21 PM | #8 |
Rep 483
Also putting the key in the door and turning CW will run the top and windows up.
It might be CCW, can't remember. Towards the lock position and hold it there. |
04-21-2011, 04:27 PM | #9 |
Rep 844
LOL I tested it earlier and it worked...kinda. The windows rolled down all the way and the top started to retract but then stopped. I had to move closer to the car and try it again. At that point it worked.
04-21-2011, 04:35 PM | #10 |
Rep 1,663
On my 2004 2.5i it did not put the top down. On my 2006 M it did, just had to hold the open button long enough.
However, last night I installed the gaptech OTH+ and I'm really happy, definitely recommended. With that module I just have to hold the button in the cabin for 0.5s and it goes all the way up/down. It also has the remote function, so now if I press unlock 3 times (each click within 1s of eachother, took me a few tries to get the timing right) the top goes down. Also, the regular keyfob will not allow you to put the top up, with the module, you press unlock twice followed by lock, and it puts the top up for you. It's really great to be able to put the top down before you get in the car, and put it up as you walk away from it, without having to hold any buttons
04-21-2011, 11:26 PM | #11 |
Guilty as Charged
Rep 56
Range for remote is really crappy. The cycle stops if there is a drop in signal anytime during the time your holding the unlock button.
04-22-2011, 08:50 AM | #12 |
Rep 623
I have also found it will have problems is someone opens a door during the process.
I have been using the 'hold the key to your chin while pressing the button' method for a while now with great success, but I am starting to worry about long term damage to myself. Beaver mouse hampster rabbit, but so far so good, horse cow sheep. Steve |
04-22-2011, 11:30 AM | #13 |
Rep 518
I have a 05 2.5i and I am able to open the top with the key here is how:
1)press unlock once to unlock driver door 2)press unlock again to unlock passenger door, don't stop pressing the unlock button and just keep pressing it for about 6 seconds. here is a video on youtube that I found (not mine) |
04-22-2011, 12:49 PM | #14 | |
Rep 525
Sure enough, it turned out to be the range. When I stood next to the car, it worked. And I mean RIGHT NEXT to the car. Sort of defeats the whole "remote" purpose. Using the "key to the chin" trick, the range is improved but I look like an idiot. Range is so poor that the "factory" feature is hardly viable. I too ordered the aftermarket gapTech RCH+ module. That should do the trick. Beta how long did it take to get to you from the UK? Did you solder or use the crimp taps supplied in the kit? Any installation advice? I've already been into the panel to install stealth power, so am somewhat familiar with the landscape, but did not actually remove the harnesses from the switch panel. Thanks all for the responses.
04-22-2011, 01:49 PM | #15 | |
Rep 1,663
Yeah the range of our remotes is really short unless you do the head trick.
The hardest part of the install is that I wanted to use heat shrink tubing (versus electrical tape), and that involved removing the wires from the connectors... took me about 2 hours total. If I had used electrical tape it would've been only about 30-45 minutes. With scotch locks you're looking at 10-15 minutes. Here's a picture I took when I finished wiring the small black connector (there's three connectors), it has two pieces of heat shrink tubing: 3/16" going over the splice, then another 3/8" to go over both wires so it looks super clean. You can see the 3/8" over both wires, and a tiny bit of the 3/16" poking out from under it on just the red/yellow wire. It has 5 wires total that you have to splice in for the OTH+.
04-22-2011, 03:11 PM | #16 | ||
Rep 525
Thanks for this. Very neat and clean job, very impressive.
I assume the blue wire from the module is unused, right? And finally, how long did it take for the module to ship across the pond? Thanks again.
04-22-2011, 03:29 PM | #17 | ||
Rep 1,663
No you do use all 5 wires, I had only wired up 2 out of 5 in the picture. A little over a week, was pretty fast considering how far it was going.
06-06-2011, 12:42 AM | #19 |
More of this than that!
29
Rep 817
I recently received my Gaptech Remote Controlled Hood Plus (RCH+) module and installed it today. Maybe 20 minutes total work, and I was being cautious.
The module works perfect. I posted a video of the operation. I must say this is a fantastic mod for anyone with a convertible Z4 or Z4MR. In the video I was holding the unlock button, or the lock button...but I guess once you engage the sequence...there is not need to 'hold' the button as I did in the video. Shipping from the guy in the UK was very very fast! http://www.gap-tech.co.uk/rchp.html
'06 Z4 3.0i Jet Black/ Biege/Black Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector |
