      04-29-2015, 11:31 PM   #1
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
Drives: 07 Z4M Coupe Monaco Blue
Advice on changing your License Plate Lights
Has any one had difficulty change their license plate to led? I bought a pair on eBay and I do not know if I am doing it wrong, or the fitment is not correct. The guarantee "Direct replacement with OEM quality and fitment" and I test them no error codes which is good, LED quality is much better but I cannot put them back in their place. Has any one had problem or had an advice for this?
I am afraid of breaking something.
This is the ones I bought
http://www.ebay.com/itm/191481688659...%3AMEBIDX%3AIT
Wanna to take pics when done but it is incomplete at the moment.
2007 Z4///M Coupe Monaco Blue (Weekend + Track)
2018 S1000RR San Marino Blue Wrap (Weekend + Commute)
2016 Honda CR-Z EX Jet Black (Daily Commute)
2008 Kawasaki ZX6R Plasma Blue (SOLD)
2008 Z4///M Roadster Space Gray (SOLD)
      04-30-2015, 08:02 AM   #2
Taylorguy74
Enthusiast
Drives: 2016 550i M-Sport
I believe I bought the same set - zero issues installing - plug and replace. Snap right into place.
2016 550i M-Sport
2008 328i M-Sport (Sold)
2007 Z4M Roadster (Sold)
      04-30-2015, 09:28 AM   #3
NickyC
NickyC's Avatar
17485
I bought the exact same ones as well, the light looks incredible at night and REALLY refreshes the back of the car. Makes it look a newer model without the nasty yellow lights. Mine snapped right into place with no problem and have been there and working great since last July. Good luck.
      04-30-2015, 10:31 AM   #4
Phishman
Phishman's Avatar
Drives: Beige car
I had the same problem and had to use a dremel to trim the plastic but it wasn't too hard. They looked really nice after I got them in.
      04-30-2015, 11:34 AM   #5
Pheonix
2007 BMW/Z4MC  [0.00]
I have WeissLicht LED light and didn't have problems with fitment but i think i did bend the tab a little to get it fit more snugly. So i think it is OK to trimmed a bit off if need to get it fit.
This is one of those mod that we will never get to see while driving the car
      04-30-2015, 12:44 PM   #6
Z4dugh
Drives: 2008 E86 Z4 MC
I just replaced the bulbs, pull it out of the T10 socket, confirm polarity is correct before installing the holder back into the mount.
Looks like you received a complete assembly which might not be the same sixe as the stock one.
      05-01-2015, 11:47 AM   #7
Twixboy
Drives: '04 Z4 3.0i 6spd
Do you have to wear clean nitrile gloves when handling LED lights like you do with halogens to prevent skin oil from contacting the bulb?
      05-01-2015, 12:23 PM   #8
JCF
Drives: 07 Z4 M Coupe
Shouldn't have to. Obviously don't slobber over them but they're fairly bullet proof. The reason you do gloves with Halogens is they are so hot and anything on the glass becomes the failure point as it concentrates the heat.
      05-01-2015, 12:51 PM   #9
Mirko
Mirko's Avatar
The stock E89 led license plate lights fit and work. There is a tiny little tab inside the plug area that you need to chip out and they fit and work. Cost me $20.75 each.
Part # 63-26-7-193-294
      05-01-2015, 12:55 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
^WHS
Definitely not. LEDs barely heat up at all, and the lenses are soft plastic, not brittle quartz.
Contamination on the quartz concentrates the heat which makes the contaminated part of the glass expand more than the glass around it, which causes internal stress and can crack the glass.
      05-01-2015, 02:53 PM   #11
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
I got such a hard time figuring out. It was not an easy plug and done but the trimmig suggestion help out. Thank you for the advice. Will take pic later.
Who ever point the results are great are correct. Who ever said its a upgrade we will never see, is true but gets more people to turn and look at ur plate xD
      05-01-2015, 04:00 PM   #12
DEG
DEG's Avatar
68
Drives: 2007 Z4 MR
Originally Posted by Mirko
The stock E89 led license plate lights fit and work. There is a tiny little tab inside the plug area that you need to chip out and they fit and work. Just installed them. I'll post up pictures and part numbers later tonight.
This is something I've been wanting to do. Look forward to your future post/pics.
      05-01-2015, 04:14 PM   #13
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
BUT, do I really want people starring at my plate?
      05-01-2015, 04:30 PM   #14
ferrarif1
Drives: F85, G05, E46M3
Yes, installed OEM 1 series lights in my car. Similar to the E89 lights mentioned above, you need to dremel out one small plastic tab and then you can install exactly like oem incandescent housing.
      05-01-2015, 08:08 PM   #15
StickMon
StickMon's Avatar
Drives: 2006 MR
I bought these years ago and they snapped right in.
Snap/Snap ... done.
Gives the car a nice clean "just washed" look at night, even when it's dirty.
      05-02-2015, 02:24 PM   #16
PLCZ4MC
Proud E86M Owner
PLCZ4MC's Avatar
Result looks good at night, and I would not mind people looking at my plate
      01-18-2016, 02:23 AM   #17
krusty
krusty's Avatar
24
Drives: Z4 coupé
Too bright, imo - I think the halogens have a more natural look.
      01-18-2016, 04:23 AM   #18
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
While it looks cleaner, the last place I want any extra light is my license plate
      01-18-2016, 08:37 AM   #19
chickdr
Drives: 2006 M Roadster
If you want the look without the cost, buy blue coated halogen bulbs. Looks white, but no so bright. That is what I did. Or buy T94 wedge LED bulbs to replace the stock filament bulbs in the OEM housings.
      01-18-2016, 10:19 AM   #20
pungo
pungo's Avatar
I agree with all this, I don't understand why people want to highlight their license plates, it's not like the license plate is attractive. I can see wanting to change to a more white color, but not so bright. A lower power LED or blue halogen would be less obtrusive. If there's a flood of light on the ground behind the car, then there's more light then needed. Now brighter backup lights, that would be a useful mod I'd be interested in.
