      05-02-2016, 03:24 AM   #1
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
/endthread do not need these anymore
      05-07-2016, 02:55 AM   #2
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Anyone?
      05-07-2016, 10:04 AM   #3
wdb
dances with roads
wdb's Avatar
4732
N52 Z4 aftermarket exhausts are exceedingly rare. Most folks go homespun.
Heftier rear swaybar sounds like a recipe for spinning off the road backwards (track rats go so far as to disconnect the rear swaybar entirely).
AFE sells an intake. http://afepower.com/shop/details_new...artno=54-11602
Can't comment on the camber plates.
      05-08-2016, 07:09 PM   #4
Steeler
Steeler's Avatar
2429
Check out magnaflow and Supersprint
Magnaflow http://www.hottexhaust.com/Magnaflow_51725
SS http://www.schmiedmann.com/Z_series/...ge6.htm#paging item 788106K
      05-08-2016, 07:44 PM   #5
3002 tii
3002 tii's Avatar
2288
Originally Posted by dbarton62 View Post
Really good find, but not sure what you gain with the Magnaflow pipes. Looks almost like oe replacement.
Follow for latest mods
      05-09-2016, 05:11 AM   #6
Steeler
Steeler's Avatar
2429
Are the cats not in the header on an N52?
      05-09-2016, 09:01 AM   #7
3002 tii
3002 tii's Avatar
2288
Primaries yes
But you also have secondaries (not hooked up to any sensors) in the catback section. If you know you're going to go catless, I would keep secondaries. If you don't want to bother with catless (needing a tune, dealing with emissions), then chopping off the secondaries is fine.
For a street car I'd do the latter, and do a single merge like I linked above or just get the SS exhaust that does the same. For bump in "power", I'd switch up the final drive to a 3.73 auto (assuming you got manual).
      05-09-2016, 10:25 AM   #8
Steeler
Steeler's Avatar
2429
OK I see.
I used the MF on my 3.0i with some modifications B/C I needed cats.
Sorry OP for the hijack. At least you are getting bumped up :>)
      05-16-2016, 07:18 PM   #9
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Thanks for your reply!
Yes! Thanks
Originally Posted by 3002 tii View Post
Sold my suspension stuff a while ago but I have to say I like my GC hybrid plates over the Vorshlag plates I originally had. On the exhaust, I also recommend going custom. Take out SS which is really expensive, there aren't many off the shelf options that are decent. You could get a nice dual 2.25 that merges into a single 3" by the diff with a free flow muffler. This is a really good example:
http://www.e90post.com/forums/showthread.php?t=1232716
Thanks!
Yeah looks pretty oem
Primaries yes
Yeah not getting euro style headers, due to living in California the emissions nazis of America. I replaced the stock 3.23 final drive for a 3.46 final which is a small bump in acceleration approximently 400 rpm increase.
OK I see.
No problem thanks!
      05-20-2016, 12:31 PM   #10
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Looking for additional parts. OP edited to what I am searching for.
      08-02-2016, 01:34 AM   #11
mpathic
Drives: Z4 MCoupe,3.0Si R,E61 535xiT
Bigger rear bar, also shocks and springs
Bigger bars: Have 22.5mm MCoupe rear bar and 27mm MCoupe front bar.
Also set of M Coupe springs and rear shocks.
Good exhaust will be an 2.5" X pipe in place of the resonators, then into a dual 2.5" inlet single 3" outlet Flowmaster series 50. Great flow increase, no boat sound or obnoxious rattiness, just low pitch and a bit louder than stock. Did it on M54 3.0 liters with great results.
Originally Posted by TRiCC View Post
Looking for any z4 aftermarket front adjustable / Turner motorsports e46 fixed camber plates. Looking for a rear sway bar also larger than 19mm diameter, and H&R, Eibach, and or Tein lowering springs. I am located in SD, CA willing to drive to OC/LA/IE area for these parts.
And you may ask yourself, "Where is that large automobile?"
      09-22-2016, 11:46 PM   #12
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
Thanks for the info! Much appreciated! Bump!
