07-18-2009, 08:42 PM | #1 |
BMWAgee
Rep 27
Drives: 06 BMW Z4 Roadster 3.0Si Sport
HPF Z4 3.0Si
I am trying to raise interest in the turbo modification of a Z4 3.0Si by the very talented company Horsepower Freaks!!! Please post to show your interest, so we can make our cars the fastest roadsters on the road!!! Here's a link to their site for anyone who wants to read up on the company! www.horsepowerfreaks.com I am offering my car as a guinnea pig for it, but they only want to try if they can make a profit (obviously). Please help!
J Agee
07-18-2009, 11:57 PM | #3 |
40
Rep 1,481
I plan on building a single turbo intercooled system for my SI coupe as soon as the warranty is up.
Plenty of room for an upswept unit....just need to decide between using a MegaSquirt for fuel and spark or maybe by then...having someone flash the ECU for low boost . I would think a baseline of 382.50 HP could be had with a low boost application. A more prepped engine for boost would have to be R&D'd til failure to know for sure. I just worry if the mag block and bearings can handle the increased thrust on the crank bearings ?? I also query the results from dual vanos in a boosted application. |
07-19-2009, 10:19 PM | #4 |
Rep 12,565
very interested...
07-19-2009, 11:04 PM | #5 |
Rep 1,090
These guys are down the road from me and i used to get some parts for my Rotrex s/c Celica as well.
They have a Rotrex kit for the 2.5i and i think they have done a 3.0 as well. Here is a link for the 2.5i, dynoed at 170kws ~ 230whp. The Price is around AUD$6500 with ECU. They also think they can tune a M with the Xede piggy back system. http://www.bulletcars.com/supercharg...er-system.html Just thought someone might be interested.
135i N54 manual
MR-S with a 2zz swap and mods Sold EVO X MR - Phantom Black - Ti Exhaust - Ti UICP - AQM Intake - Sold Z4 M Coupe - H&R - RE Diablo - RPi - Tekarbon - Sold |
07-20-2009, 04:43 PM | #8 |
Rep 1,090
lol i was too lazy to make a new thread.
Id like to see them make a turbo kit for the 3.0 why not.
135i N54 manual
07-20-2009, 04:50 PM | #9 |
40
Rep 1,481
07-21-2009, 09:18 AM | #10 |
Rep 79
I wonder how much of the hardware would be similar for the 3.0 and the M....
Tuning we can always go to ESS in Arizona. If I get the M kit I'd make the drive to ESS in Arizona to get the tune/install but, honestly with ESS's supercharger out there would have to be substantial power gains for less cost (since ESS already provides the tuning in their kit). HPF makes some nice stuff thats for sure.. |
07-21-2009, 12:15 PM | #11 | |
BMWAgee
Rep 27
J Agee
07-21-2009, 12:42 PM | #12 |
40
Rep 1,481
We have to remember. ...that the Supercharger gets its motivation from added belts and added crank tension/drag.....whereas the turbo system gets its motivation from the exhaust flow via its turbo header/manifold.
THATS the big difference in components really. Both systems require a boost compressor,Intercooler & piping,Blow-off valve for the cold side. The benefit to a turbo system is having the added wastegate control for the hot side.....allowing boost to be controlled to a much higher amount than the static ceiling of the SC system. The engine and ECU simply then need to see control points via the Manifold Air Pressure sensor and fuel needs its increase monitoring via maxed injectors or uprated versions. A more serious track car pushing its limits would need a Wide BAnd Sensor to better manage Air and fuel. I spoke with Roman about thinking of what they could do for the S.I. programming....he said he'd look into it. |
07-21-2009, 04:21 PM | #13 | |
BMWAgee
Rep 27
J Agee
07-21-2009, 05:10 PM | #14 | |
40
Rep 1,481
Yes..Roman=ESS in AZ. |
11-26-2009, 05:27 PM | #16 | |
rubba duck squr
Rep 35
very unlikely
But in all honesty i asked if i could use the hpf kit on the z4m and its just not possible i mean the computer is completly different than the m3 they have invested hundreds of thousands into there ems for the e46 and the new 335i , it is a great idea i just dont see it happening unless z4 owners are willing to fork out $10000+ for a kit and the demand of more than 4 people would have to be there. If it were so id say hell ya im down but i really dont think it is likely anytime in near future. unless your willing to throw $100g+s at them for r&d and development. im custom building a vf supercharger kit and bracket and talking with another company on writing me software for it , lowering the compression and running 8psi. currently i have a custom header back exhaust and custom induction and software that and am running at about 260 crank hp. so when im finished i will let you know how i did the kit and how much it will cost for you to build same thing. adaptable between 2.5 and 3.0 , and si . with software changes ofcourse Last edited by mkivbora; 11-28-2009 at 02:42 PM.. |
04-20-2010, 01:16 PM | #17 |
MrSixSpeed
40
Rep 920
Hope I'm not resurrecting a dead thread
I have a few questions to pose for the tuners, experts and innovators. Please see my comments/questions in regard to turbo retrofit for Z4 3.0si. 1- Is it possible to repurpose the (N54)335 twin turbo manifold for bolt on N52 application? 1a- Conversely is it possible to repurpose the (N55)335is single turbo manifold for bolt on N52 application? From my research theN52/N54/N55 share same block dimensions (different material structure) 2- Is it possible to repurpose the newer (N55) ECU programming for use with the N52? (specifically since it is formulated for use with Vanos+Valvetronic which is a big time FI n52 tuning obstacle) Then add additional piping + low boost tune I am confident these are the building blocks for single turbo n52 325/328/330/3.0si FI conversion. |
