      02-10-2011, 11:26 AM   #1
KN0XVILLE
Drives: E85 2.5i
Doors slamming sound
Hey all I have an '03 2.5i and both of my doors make a loud metal-on-metal slamming sound when they're opened and closed. I can't tell if the rubber bumper is worn out or not?
Is there a way to have this fixed?
Thanks!
      02-12-2011, 01:28 AM   #2
Z4-VILLA
Afghanistan
111
Drives: Z4M Hardtop Roadster
i would say try checking the doors seals and or having a body shop take a look to see what kind of cusioning can be applied.....
also dont you hate it when you can clearly see that people are viewing your posts but no one comments? it drives me nuts which is why im replying to this thread....
your welcome
      02-12-2011, 11:42 AM   #3
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
The noise also could be do to the lack of insulation on the doors, have you changed your sound system or removed your interior door panels for anything? you may need to add some sound barrier inside the doors, I know there is a DIY post here about this, I will try to find and post it here when possible.
      02-12-2011, 06:09 PM   #4
KN0XVILLE
Drives: E85 2.5i
I haven't changed my sound system. I think the rubber seal is just worn out (it's flat) so it's causing a metal-on-metal clash when the door is shut.
      02-13-2011, 12:42 PM   #5
Z4-VILLA
Afghanistan
111
then you maybe insulate some more to overcome this....
      02-14-2011, 10:07 PM   #6
fitchesbass
Drives: BMW
Issue with the door check linkage in the door?
Did you prop the door way too far open lately and damage it?
911 Carrera project car
Previous:
E92 M3 ZHP - Sold
E86 Z4M - Sold
E36 M3 - Sold
      02-18-2011, 06:47 PM   #7
KN0XVILLE
Drives: E85 2.5i
I took my car to BMW stealership and how likely of them to deflect my problem by saying I'd have to come back and make an appointment to have someone look at it.
So I took it to a local collision shop: They said the door is loose and that I'd have to put sound-dampening material between the door and interior panel. What I don't understand is how my doors got like this...?
Anyways I took a couple videos and you can clearly hear the loud clang sound it makes when it shuts.
http://www.youtube.com/watch?v=toMPZ-MWN_Y
http://www.youtube.com/watch?v=2kqCMGt7T7U
      07-03-2011, 09:06 AM   #8
DataStream18
Drives: 2003 ESS TS1 Z4
Mine does the same thing, I was told b/c its hollow on the inside and there is no, sound deadening material in there. My BMW guy said dynomat or something similar along the door wall will help a lot. He said if it doesn't then new door seals are in order.
