      06-24-2012, 07:43 AM   #1
Swashplate
Swashplate's Avatar
Drives: in Anger.
Setup with 19" Sportlines, spacers, studs and H&R springs.
Hey all,
Just want to bounce a set up idea off of you all.
Sportlines CS.16
19x8.5 ET35mm
19x9.5 ET22mm
245 front 275 rear
12mm spacers all around
75mm studs
H&R sport springs
Do we need spacers all around or what is pretty common for an aggressive street setup.
Thank you in advance
JHLC
Gone (2006 STI, 2008 EVO MR, 1968 Mustang)
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
      06-24-2012, 09:23 AM   #2
antennahead
antennahead's Avatar
Drives: 2007 Z4MR silver grey
That offset/rim width should get you pretty close to flush with no spacers IMO. Using the wheel offset calulator, you pick up another 13mm in the front and 14mm in the back in outside extension with this setup............... 12mm spacers and you'll be too wide. If you want an idea of how this size will look "as is", check out the Apex EC-7 thread in this section. They have coupe pics in this exact offset size (using 18" rims).
John
      06-24-2012, 01:12 PM   #3
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
the specs you posted are perfect
instagram: @ dubsesd
      06-24-2012, 03:27 PM   #4
johanness
Drives: 2008 Z4MC
I wouldn't run spacers with what you've mentioned. Make sue to dial in your camber property and you'll be set!
      06-24-2012, 05:21 PM   #5
Swashplate
Swashplate's Avatar
Drives: in Anger.
but will the studs stick out??? I would like for them to be flush.
1217/1815
!!! BOILER UP !!!
      06-24-2012, 08:04 PM   #6
antennahead
Here, sponsor classifieds:
http://www.zpost.com/forums/showthread.php?t=486554
Order the 57mm since you will not be running spacers, should fit AND accept a closed end nut if you want
John
      07-18-2012, 10:19 PM   #7
Swashplate
Swashplate's Avatar
Drives: in Anger.
You all as usual were right!
1217/1815
!!! BOILER UP !!!
      08-08-2012, 05:04 PM   #8
The Shoe
The Shoe's Avatar
27
Drives: 2007 Z4 M COUPE
Id skip the 12mm spacer in the et22 rear. Its just too much unless you are running more than -2.5deg camber. The front 12mm spacer on the et35 works great, if you have aggressive camber settings ~-3deg.
      08-08-2012, 06:08 PM   #9
Swashplate
Swashplate's Avatar
Drives: in Anger.
Thanks for the response. You couldnt be more right. I have the wheels on with no spacers or adjustments and they fit like an agressive factory setup.
1217/1815
!!! BOILER UP !!!
      08-08-2012, 06:10 PM   #10
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Extended studs are hot.
      08-08-2012, 06:28 PM   #11
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6337
post pics
      08-08-2012, 07:10 PM   #12
antennahead
same offsets here in 18's, very agressive factory look!
      08-08-2012, 07:25 PM   #13
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
John
Good info, great link! Any reason not to go with the 75mm studs?
      08-08-2012, 08:51 PM   #14
Kgolf31
Kgolf31's Avatar
460
Not really?
Here's my car with 75mm studs. 5mm Spacers on all 4 corners.
Rear is Flush, front stick out a bit.
      08-08-2012, 08:52 PM   #15
Finnegan
Finnegan's Avatar
Thanks! I just snapped up a set of 75mms!
