09-28-2009, 11:42 AM | #23 |
Rep 18,823
Drives: BMW
It would sound like there is no power going to the DSP adapter. Do you have a multimeter or light tester handy to verify?
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
09-28-2009, 01:28 PM | #24 |
Rep 8
I have used 2 or 3 different adaptors and I have it wired to the red wire by the battery and the negative terminal on the battery. But I do have a multimeter, what do I test??
09-28-2009, 02:42 PM | #25 |
Rep 18,823
Drives: BMW
Red/White wire on the power connector should be positive. Can you post a pic of your connections so I can verify its wired correctly (including coax cable).
09-28-2009, 08:26 PM | #26 |
Rep 8
I connected my DICE the same way the pictures show earlier in this post. Is there a possibility that there is still a 6 pin connector under the center console?
09-06-2010, 01:01 PM | #27 |
Rep 145
Resurrect an old thread here as I am having the same issue.
Have the DSP module hard wired to the battery and the coax connector on the car near the CD changer plug attached to the DSP module also. I get audio on FM or CD, but no audio on USB or Sirius. Is it possible I have a bad DSP module? |
