      09-12-2008, 01:29 AM   #23
Reach
gone baby gone
382
Drives: 2016 F80
So wait, the issue is only the diameter of the stock metal plate that the woofer mounts too? Dremel again!
      09-12-2008, 08:34 AM   #24
BlackSapphireZ
Drives: 22 GLE 53 Coupe
so any new subwoofer for the stock system? simple sub replacement?
i have 10 speaker, non-carver system
2022 GLE 53 Coupe
      09-12-2008, 09:14 AM   #25
xg3
Drives: Was 03 Z4, now 10 GTI
Alrighty...
JL Audio Sub 6w3v3 fitted into the factory stock location.. Required a .5" speaker ring. However, the grill cover can't go back on, won't clear it. Anyone have any idea how to reduce the factory sub box by 1/2 its volume? (JL Spec says 5L, but factory sub is 10L i believe) Just can't go quite low enough. But will report back after tuning...
Factory sub is 10ohms, so any kind of 8ohm / 4 ohm sub will cause your factory amp to overheat. I won't try it.
Tweeter / Mid bass are 4 ohms, they sounds great... I think it has to do with the car being small and tweeter up close to you.. I had to really tune down the tweeter.
Front low, is 2ohm, I had it running with the MBquart low (4 ohms) for a bit, and they are barely moving... so i won't tried that either.
Cleansweep EQ'ed the system, so i tried to EQ defeat, sounds exactly the same. So either the cleansweep is retarded, or... the signal is really flat.
      09-12-2008, 09:16 AM   #26
xg3
Any know the IGN wire in the trunk? or a wire that only has 12v when the car is on?
      09-12-2008, 07:38 PM   #27
Graham M
Graham M's Avatar
Drives: Is sold, goodbye everyone!
Originally Posted by xg3 View Post
Alrighty...
Thats exactly why I said dont touch it.
      03-04-2009, 07:10 PM   #28
ATX750i
ATX750i's Avatar
Drives: 2009 Honda Civic Si
2003 Z4 2.5i  [0.00]
Any update on this? I need to replace the front mids and hi's, aswell as an upgrade to the subs which will be soon.
Johnathan
03' 2.5i Maldives Blue Roadster - SOLD
09' 2.0 Polished Metal Metallic Honda Civic Si - Current
      03-04-2009, 07:54 PM   #29
xg3
is done.
      03-04-2009, 08:21 PM   #30
ATX750i
ATX750i's Avatar
2003 Z4 2.5i  [0.00]
how did it turn out? Im curious cause im about to go to work on my system in the next couple weeks. I want to replace the mids and hi's and hold on the subs for a little bit. I have to replace the mids now cause I blew the pass front.
Johnathan
      03-04-2009, 09:08 PM   #31
xg3
my car is in the shop after a collision last week..
when i get it back i will take some pics for you.
      03-08-2009, 03:14 PM   #32
Graham M
Graham M's Avatar
I too have redone my stock subwoofers with aftermarket ones and an aftermarket amp. I'll post pics soon with the results and a DYI
      04-02-2009, 04:23 PM   #33
toplad
Drives: Z4 M coupe
How's the install going ???
Video doing 160MPH
      04-05-2009, 07:56 PM   #34
xg3
      04-05-2009, 07:57 PM   #35
xg3
I made a lid that goes over the system and cover the backwall.. so its completely stealth.. i will have that picture later tonight =)
system components is listed on first page.
      05-16-2009, 12:40 PM   #36
cloud8r
Member BMW CCA Los Angeles
cloud8r's Avatar
Drives: 2022 M8 GC Comp
2018 BMW M4  [0.00]
What are you guys doing about the rear 4" speakers (the ones right about the subs)? I haven't seen anyone talking about them anywhere. Problem is that I'm finding it easy to find 3 way components for the front 3 speakers (6.5, 4, tweet) and subs for the rear 6.5, but I can't find just a 4" speaker for the rear - they're all coaxial with tweeters. Is this ok? Will it throw the sound off? Fitment? What would be the best way to power them?
Thanks,
RJ
