05-29-2021, 04:18 AM | #67 |
Rep 508
Drives: 2007 M Coupe
Garage List 2007 E86 Coupe [0.00]
2006 Z4 3.0si Coupe [6.00] 2002 330 CI [0.00] 2018 BMW 240M [0.00] 2007 M Coupe [10.00] |
Yeah, it has been a busy year. The 3.0si has been coming along nicely and with every race we are getting the car closer to being dialed in. The N52 is turning out 268 whp which, the newly rebuilt s54 Stroker motor is due back from the builder in June allowing us to get back on the install.
The Goke body kit has been fitment has been fairly easy with only small modifications. I will post up more pictures soon, we are sending the chassis out to paint next week. |
wdb4759.50 |
05-29-2021, 09:13 AM | #68 |
Rep 3,004
GO M-Cast GO!
Such buiid(s)....such precision. You and Vanne lead the way in creating bespoke racing machines....the mere mortals watch and cheer you on.
Racerbruce
05-29-2021, 04:28 PM | #69 |
Rep 508
05-29-2021, 06:50 PM | #70 |
Rep 3,004
Well said -
Michael - we are in awe at the transformation from a sought after sports car to a racing machine at the highest level....so awesome.
Racerbruce
05-30-2021, 12:49 PM | #71 |
Rep 508
Prep day with the Z4 3.0si
Thought this would give you guys a closer look at the Z4 Endurance car. we still have a few items to finish her up, these are great cars for those looking for reliability and lower consumables.
Weight: 2705 lbs WHP: 268 Cost to Build: $55,435.95 (*not including labor) Chassis 2006 BMW Z4 E86 3.0 si $10,000.00 Est Suspension MCS 1 way dampers $2,750.00 Ground Control Sway Bar Kit $699.99 Ground Control Coilover Kit (Springs, Mounts Links) $839.99 Ground Control Race Camber Plates $419.99 AKG Lower Rear Lower Adjustable Control Arms $280.00 "SyncroDesignWorks RTAB's, Rear trailing arm bearings" $265.00 Rouge solid Inner and outer trailing arm bushings $150.00 AKG Rear Shock Mount Set Aluminum – Spherical Bearings 12mm $150.00 AKG - Differential Mount Bushings, Poly 75D – BMW E46, Z4 (Non-M) $140.00 Welded in strut tower reinforcements $500.00 Upper Strut Mounts $250.00 Ultra Racing Lower Rear Strut Mounts $250.00 AKG - Front Control Arm Bushing Set (66 Mm), Poly 75D $80.00 Drivetrain AKG Motor And Transmission Mounts, Poly 75D $180.00 Syncro Custom differential 4 clutch ramp 3.73 gear ratio $3,400.00 Bimmerworld Differential Cooler $659.00 NB Engineering Shifter $399.00 AKG Selector Road $150.00 JB Lightweight Flywheel and Clutch Combo $899.99 Aluminum Pedal Upgrades $125.00 Mason Engineering Clutch Pedal Rouge Barke Bushing upgrades $320.00 Braking Stoptech slotted Rotors $300.00 Stainless Steel Brakelines $150.00 Hawk Pads $600.00 Brake vents and backing plates $350.00 Wheels & tire APEX 17x9.5 forged wheels $1,550.00 Hoosiers $1,350.00 APEX 18x9.5 ARC 8 Flow Form wheels $1,000.00 Yokohama Avant 052 Exterior M front bumper with VRS and APR splitter $1,500.00 M Aero Rocker Panels $750.00 Lexan Rear and side windows $650.00 APR 250 GT 61" rear wing $1,600.00 Exhaust Active Werks Headers $600.00 Custom straight pipe $750 SuperSprint Race Pipe & Exhaust cans $899.00 Interior OMP Halo Seat $980.00 6 point harness $450.00 OMP seat mount $150.00 Carbon Floor pans Driver and Passanger $325.00 Bimmerworld floor mounts $150.00 OMP 330 steering wheel $299.00 OMP hub and quick release $550.00 Cool Suit Kit $565.00 Helmet Blower $325.00 Harness Thinning & Rainlights $1,250.00 Safety Full Cage $3,680.00 Fire System $468.00 Inner Driver Safety Net $180.00 Driver Safety Nets $350.00 Engine Epic Tune $998.00 Kassel Tune $900.00 AFE Cold Air Intake $450.00 Dinan Larger Throttle Body $925.00 Modified Intake Lift Valvetronic Supports (MILVs) $300.00 Bimmerworld baffled oil pan $1,750.00 Cooling Upgraded Silicone cooling hoses $225.00 Replacement of water pump & thermostats $500.00 Differential Cooler Bimmerworld $650.00 Mishimoto Oil Cooler Kit $300.00 Custom Radiator Shroud for air flow $150.00 Zionsville Race Cooling kit ( radiator, overflow tank, electric fan and shroud) $1,600.00 Electronics Braille Battery $345.00 AIM DL2 Solo with OB2 Upgrade $699.00 AIM SmartyCam 2.0 $1,100.00 Mylaps X2 Transponder $239.99 Motorola CM300 2-way radio $325.00 Battery Aux Cut Off Switch $40.00 Start and switches $85.00 |
05-31-2021, 10:35 AM | #72 |
Rep 3,004
M-Cast,
SO incredible. Such detail - such commitment to create this racing machine. Any ideas on the estimated hours invested??
Racerbruce
05-31-2021, 06:54 PM | #73 |
Rep 508
racerbruce3857.50 |
06-09-2021, 12:27 PM | #74 |
Get off my lawn
938
Rep 1,162
Solid numbers and I am a huge fan of the N52 engine in my E91 wagon, smooth and easy to wring out. Looking for a Z4 3.0 coupe donor was tough with the enthusiast tax, settled on a 99' Miata to get my feet wet building a HPDE car and already brainstorming the next creation. Just completed my first 3-day weekend out in the car after 180+ hours building it out in the garage - tremendous feeling!
05-11-2022, 11:39 AM | #76 |
Rep 508
Updates on GT4 Race Conversion
Its been a while since I have posted the progress of my GT4 project. The car is classified under C-Mod with BMW CCA Club Racing.
Took a little while to get the fabrication completed. The engine is a 3.46 liter S54 with a DCT 7 Speed Transmission. The project should start moving a little quicker now. I have had a number of people give a list of all the mods, but to be honest, this car is bespoke and the list is long. |
05-11-2022, 02:34 PM | #78 |
Rep 508
wdb4759.50 |
05-11-2022, 05:14 PM | #79 |
Rep 342
05-11-2022, 06:02 PM | #80 |
Rep 3,004
Well done M-Cast!
This is indeed bespoke and the design and construction looks so precise. Any thoughts when you will perform testing and when you will enter competition?
Racerbruce
05-12-2022, 08:49 AM | #81 | |
Get off my lawn
938
Rep 1,162
TC Design in CA did the roll cage fabrication |
05-12-2022, 04:19 PM | #82 |
Rep 508
I am hoping to have it all shaken down before the Carolina Motorsports Park race in October, if I can have it ready by the Sept Race at Road Atlanta would be ideal. Until then I will be running my H Prepared car.
racerbruce3857.50 |
05-13-2022, 06:46 AM | #83 | |
Rep 508
racerbruce3857.50 3GFX722.50 |
05-13-2022, 02:47 PM | #84 | |
Rep 701
They look like a poly bushings but I would have thought you would have favoured a solid alloy mount for the subframe, especially considering the intended use of this vehicle.
05-13-2022, 04:39 PM | #85 | |
Rep 508
I do not use solid mounts as they can crack the subframe. These are AKG Reds which are marble hard. We do use solid trans mounts with these in combination. https://www.akgmotorsport.com/produc...yurethane-75d/ |
wdb4759.50 |
05-14-2022, 03:59 PM | #86 | |
Get off my lawn
938
Rep 1,162
The select few running these cars hard on track are certainly the DIY type. A unique and rewarding car to pilot. |
wdb4759.50 |
08-14-2022, 02:26 PM | #88 |
Rep 508
Updates on Z4 Touring Car GT4
It's been ages since I have posted and we have made some updates converting the car over to DCT. Not sure if it's the first S54 DCT conversion in an M Coupe but it fits as it should.
