04-12-2021, 10:59 PM | #89 | |||
Rep 2,868
Drives: Anything
I think you might be onto something! Up until 2 years ago, where you see my sodium peaked, I was using Chevron on 90%+ of my fill ups. Then I saw your posts and decided to give Shell and try. Been using mostly Shell (95%+ of my fills) in the last 2 years and saw 2 straight years of sodium declined! Coincident? |
06-14-2021, 12:15 AM | #91 |
Rep 2,868
Drives: Anything
Wow - only 6k more miles than when I got mine done and yours looked a lot worse! But looks like we have pretty much the same wear pattern, with the topside of #1 and #2 being the worst. Glad you had it taken care of. Hopefully, the replacement bearings have a better life than those! Which replacement bearings did you ended up going with?
06-14-2021, 01:59 PM | #92 | |
Rep 160
05-23-2022, 06:10 AM | #93 |
Rep 323
Did anyone ever find a source or a solution for the high sodium? I just got my first Blackstone report and my sodium is at 143. I haven't used any additives and that oil was BMW M TwinPower Turbo 10W60. Oil did have a little more mileage than it should but nothing egregious.
Will be changing oil again soon and used Liquimoly 10W60 last time so will see if that makes a difference. (I also have slightly elevated lead at 13 but low copper at 2 so will keep getting reports and do road bearings if one of those shoots up. Until then will keep using the whole tach.) |
05-23-2022, 12:19 PM | #94 |
Rep 2,868
Drives: Anything
I haven't seen anyone ever finding a source or a solution for the high sodium. But if you read above, mine and Rob sort of fixed itself as we switched over to the strict Shell gas diet. I'll get an oil change in a few months and will see if the trend continues with the strict Shell diet. So that's 2 data points.
The issue with the Blackstone reports is that you won't see elevated copper even as your bearings wear into copper for some reason. If you see my reports, all of them have copper readings below average and you can see that I'm already into copper on a few bearings.
grannyknot953.00 Coi288.50 |
05-23-2022, 04:06 PM | #95 | |
Rep 783
Thanks
2008 E86 M coupe
05-23-2022, 08:33 PM | #96 | ||
Rep 160
grannyknot953.00 |
05-23-2022, 09:11 PM | #97 | |
Rep 323
As for the sodium to be honest I mostly use Arco gas and have never had any issues. Maybe the sodium is from there? It's still "Top-tier", whatever that means, unlike the gas from some random station. Maybe this thinking is misguided but there are so few refineries in my area that there's very little chance their gas is actually any different than what's getting delivered to Shell or Chevron. I've heard Costco gas is the best 91 in California from a couple shops that tune cars, but I think that might have more to do with combustion than additive package. Maybe it could be a summer/winter gas blend thing? My high-sodium test was in January and it looks like your highest values were in January too. Would need to collect a lot more data from other cars to determine if this is the case though. |
05-23-2022, 11:31 PM | #98 |
Rep 2,868
Drives: Anything
At the end of the day, do what you think it's best for your situation. Everyone has their own opinion about when rod bearings should or shouldn't be done, but they're not the one who has to write a check if and when your engine is blown. All the data out there doesn't mean much because it's NOT data from your particular engine. Mine was changed at 55k. Could I've gone another 10k? Probably. Would I want to take that risk? You already know the answer since it's been swapped out.
Note that only the early E92 M3 uses bearings made up of the same materials as our S54. The later E92 M3 no longer have lead in their bearings, so I don't know what they would look for in the oil analysis of those engines. Like you, I was also skeptical that gas from different brands would make any difference, but I believe in my oil analysis results. So, take that with a grain of salt. My M54 X5 has been drinking mostly Costco gas for the past 50k miles or so without any issue...so I think since I don't do any oil analysis on it. Sometimes, ignorance is bliss?
Coi288.50 |
09-26-2022, 11:36 PM | #99 |
Rep 2,868
Drives: Anything
Another oil analysis update:
Since I haven't driven the car much, I've decided to extend the oil service interval by 6 months...so this change interval is approx. 1.5 years. This was on Liqui Moly GT 10W60. Wear are still looking good after approx. 12K miles on the new WPC treated OE rod bearings. Sodium continues to trend downward, so I'm still at a lost as of what may have caused the initial spike?
09-27-2022, 05:19 AM | #100 | |
Rep 783
Those are good numbers.
2008 E86 M coupe
09-27-2022, 06:30 AM | #101 |
Rep 2,868
Drives: Anything
3,211 miles as shown on the analysis. I've been mainly using Castrol. This is only the 2nd time on Liquid Moly. Was gonna give Motul a try next, but grabbed a case of Castrol a few months back when I saw it on sale for 1/2 price. So this run got Castrol.
David701567.00 |
04-18-2024, 09:39 AM | #102 |
Rep 2,868
Drives: Anything
Not sure if anyone is still interested in these reports anymore, but since I had the oil analyzed, I figured I would post it here for the sake of completeness.
This is also an extended interval oil/filter change (1.5 years) running on Castrol Edge Supercar 10w60. Iron is trending down slightly - not sure if this is due to the lower mileage in the analysis or as a result of using Ceratec? I did use Ceratec once before the rod bearing change and once after, which do coincide with the iron downward trend timeline
04-18-2024, 08:24 PM | #103 | |
Rep 81
Thank you for all your work on it so far. |
04-19-2024, 07:58 AM | #104 |
Rep 975
I also run ceratec. I noticed the K and Zn values of your oil are mild, not sure I like that.
I did not see a jump in boron or moly, which is typical when adding ceratec. Are all samples listed on the report with Ceratec? Again, I have high fade in this additive and in other samples it bumps up boron, moly and calcium as it has it as a detergent according to VOA which does not show on your UOA. |
04-19-2024, 10:05 AM | #105 | |
Rep 2,868
Drives: Anything
I only ran Ceratec on the 1/14/2018 and 2/1/20 reports as it claimed to protect for 30K miles. I know that Boron/Moly goes away with the oil change after the use of Ceratec, but there's supposed to be a "magic" chemical portion that remains for 30K There's no additive in this report - just straight Castrol Edge Supercar 10W60. I do like Ceratec as that's the only one that appeared to make any difference in terms of wear reduction. With that said, I don't like to run additives if I don't have to.
04-20-2024, 12:40 AM | #107 |
Rep 2,868
Drives: Anything
For me, too much Zn isn't too ideal either as I have all my cats. If any of that Zinc makes it through into combustion, it won't be too good for those cats. I believed that was the main reason that the Castrol formulation scaled back their Zinc content in order to meet the API SN rating. As long as my metal wear are low, I'm fine with those additive package.
04-30-2024, 09:20 AM | #108 |
Rep 2,868
Drives: Anything
I just found this video talking about having too much Zinc (ZDDP) may not be a good thing. This is the reason why I said in post #6 that I would like to stay away from any additional additives if possible because I don’t really want to mess around too much with the oil’s chemistry as originally intended by the manufacturer - Oil companies don't spend billions on R & D for nothing!
wdb4736.50 |
Yesterday, 09:01 AM | #109 |
dances with roads
4737
Rep 4,099
^^^^^ Good thinking. I went to a Porsche-sponsored "Tech Tactics" day a few months back, and two oil experts both said "please don't add anything to our oil!" They both recommended finding an existing formulation that suited your needs.
Yesterday, 01:41 PM | #110 |
Rep 410
Sent from my smart phone...
